KYB-AGX Install
Old Apr 15, 2002 | 01:51 PM
SLC I30t's Avatar
KYB-AGX Install
Is there any trick to getting the whell knuckle bolts off? Or just bust your hands bloody?
Old Apr 15, 2002 | 02:07 PM
sbslacker's Avatar
Re: KYB-AGX Install
Hands bloody fo-sho! Seriously, are you taking your stock susp. off? I know mine was a BBEEEYYOOOCCHH to get off. Try a breaker bar...maybe some liquid wrench...cussing and getting mad always seems to work for me too.
Old Apr 15, 2002 | 02:35 PM
SLC I30t's Avatar
How far do I have to compress the springs
Old Apr 15, 2002 | 02:40 PM
sbslacker's Avatar
Once you get the shock/strut combo off the car, compress the spring w/ compressors until it is loose between the top & bottom perches. Then undo the center nut, take the strut mount off and then you can pull the spring off (still compressed of course) and separate it from the rest of the unit. Then carefully uncompress the spring.
Old Apr 16, 2002 | 04:50 AM
SLC I30t's Avatar
Ok I got the front done, and I still have 10 fingers, one with out skin though. To do the back, how did you guys raise the car with out damaging the lift points with your jackstands? I started to lift the car from the axle and put the jack stands on the lift points, assuming they were the strongest. as I started to lower them I noticed them bowing, I quickly raised the car again before any thing serious happend. I'm considering taking it to a suspension shop to have the rear done.
On a side note, when I lowered the front after the spring, strut switch, the car was too low to get the floor jack from underneath. he he he
Old Apr 16, 2002 | 09:01 AM
sbslacker's Avatar
If you are placing the jack stands between the notches where the manual tells you to place them and the thing is bowing, I don't know what to tell you. It shouldn't be doing that. Try raising one side of the axle only and placing that jack stand....then raise the other side of the axle and place the other jack stand.
Yeah, now that the car is lowered getting that jack under there is a PITA for sure. Good luck.
Old Apr 19, 2002 | 06:10 AM
SLC I30t's Avatar
I just did one side at a time with a floor jack. The pinch point wouldn't buckle but wherever I would jack the car up would. So I just jacked it up high enough that I put one under the axle as a safety thing and got the job done. I know what you mean about getting the jack under the car to jack it up. I can get it under on the sides but I cant do the front jack up trick anymore. Makes me mad.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
