I used the wrong oil,should I change it?
Old Apr 23, 2002 | 03:52 PM
Hunter11's Avatar
This weekend I changed my oil. I had my oil in the cabinet were I always put it after I buy it, it was out of the box. Now, I don't know if I bought the wrong oil last time I bought oil, or somebody at my house put the wrong oil in there and I didn't know it. I usually put Pennzoil 10w-30 in my car but after I did everything I noticed that I had put Pennzoil HD30 oil in my car. I don't have any idea how that oil got there, guess I might have bought it last time and didn't notice.But I think I used the same HD30 last time I changed my oil b/c after I change my oil I always put the last bottle of oil in my trunk. And the bottle in my trunk was that same HD30,so I guess I have been running on it for the last 3000 miles. I have changed my oil plenty of times and I guess I got to routine with it and didn't pay attention.
Does anyone think I should change my oil again right now to the 10w-30 or do you think I can wait another 3000 miles? Seems the car runs fine.
What kind of cars is HD30 oil for anyways? I figured the HD might be Heavy Duty?
Old Apr 23, 2002 | 05:12 PM
xHypex's Avatar
"Diesel Oil HD30 - Heavy duty motor oil for naturally aspirated diesel engines. Also suitable for VW air cooled engines."
"HD30. Heavy-duty detergent motor oil."
I found those things about HD30 by doing a search on Google. I would change the oil seeing that it's not even made for our engine. I have no idea what the side effects would be of using it, but I'm sure they aren't good.
-hype
Old Apr 23, 2002 | 05:19 PM
Frank Fontaine's Avatar
Re: I used the wrong oil,should I change it?
I think I would change it if I were you, but of course you don't need to change the filter. 30 is very heavy, designed for summer only. My grandpa used to use it in his lawn mower. I don't think 30 is good even for the blistering cold we have here in Phila. It was 42 degrees this morning, man old man winter is back! hehehe
Sometimes I think this place is psycho--pouring rain pitch black and you have cars cruising around with no lights. Common sense and Carlos Santana both tell you to put your lights on....
Old Apr 24, 2002 | 06:18 AM
iwannabmw's Avatar
That oil is a single grade oil for high temperatures. The difference between using that and a 10W-30 will be increased wear at startup and a longer warm up time which will lead to increased fuel consumption. Nissan recommends a 5W-30, but mentions a 10W-30 is preferrable if the ambient temperatures stay above 40 degrees, so a straight 30 weight is way too thick to pump/flow easily at cooler temperatures in these engines.
* The last sentence originally in this post was deleted to reflect new info brought to light in this thread.
Old Apr 24, 2002 | 07:31 AM
Hunter11's Avatar
Thanks for the info on the oil! I am planning on changing the oil again this weekend but keeping my same filter. Hopefully no damage done. Thanks
Old Apr 24, 2002 | 07:59 AM
ftb87's Avatar
Change the oil and filter. You don't want to mix oil.
BTW HD30 in not diesel oil. Any diesel oil will have a C or CH in the weight (how do I know...I also own a 2001 Dodge 2500 Cummins diesel).
Frank
Old Apr 24, 2002 | 08:49 AM
RussMaxManiac
Guys he is safe.
Read this....
http://www.pennzoil.com/TechData/pds...ils/pdf/hd.pdf
It's basically just for extreme conditions, not for diesel.
Old Apr 24, 2002 | 10:45 AM
BSwithTF's Avatar
Originally posted by RussMaxManiac
Guys he is safe.
Read this....
Except that he's using Pennzoil. I don't think safe and Pennzoil can be used in the sentence.
Old Apr 24, 2002 | 11:36 AM
RussMaxManiac
The link is Pennzoil, HD40 is for Pennzoil. And Pennzoil is rated one of the best oils you can use for dino. Catrol GTX and Pennzoil. The tests prove that.
Old Apr 24, 2002 | 05:08 PM
davis4005's Avatar
For the cost of oil, I would definitely change it, I actually enjoy chaning the oil.
Old Apr 26, 2002 | 03:34 PM
vmok's Avatar
Do this. Read the API startburst seal on it. If it meets the minimun specifications from Nissan in the manual (SH or whatever it is), then it should be ok.
-V
Old Apr 26, 2002 | 04:16 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
really?
Old Apr 26, 2002 | 04:41 PM
BBaker025's Avatar
Unless you want to F*ck up your engine, id change it. They make different grade oils for a reason
Old Apr 26, 2002 | 07:02 PM
BSwithTF's Avatar
I've had several mechanics tell me to stay away from it.
These are people that have pulled down engines that were from die hard Pennzoil users. Oh yeah, it definitely bonds to engine parts! Not in a good way though. They say it comes apart like a sticky, sludge packed mess. This is hearsay though, I have never seen this with my own eyes. I've never heard anything like that about any other oil, only Pennzoil.
97_GXE
20
Sep 17, 2015 08:12 PM
Steven Orozco
Sep 12, 2015 10:41 PM
220k+ A32
Sep 11, 2015 02:18 AM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
