Ok, i'm starting my engine project....
Old 05-08-2002, 02:28 PM
  #41
I'm needing a caw
Jeff92se's Avatar
Ah just a note. When doing this type of modification, you should almost NEVER rely on someone else's info(unless it's super source). So if you are serious about this type of work, you probably should be mic'ing all the measurements your self. ie.. bore, bearing size, piston size, ring size etc.... or buy a Nissan service manual. If you are trying to do major engine work w/o one for assembly or just for reference, you are crazy.
Jeff92se is offline
Old 05-08-2002, 07:31 PM
  #42
Screaminfast's Avatar
Well, all of the work will be done by a machine shop, and by my friends at an install shop....so I won't be touching it that much. I think I would need to go to them with guidelines though....
-Mike
Screaminfast is offline
Old 05-09-2002, 08:35 AM
  #43
bump.....
I'm going to talk to MardiGrasMax today and he's gonna help me figure out what parts I should get and some values.....I had talked to Y2KevSE a while ago, and he had given me some good ideas as well.....I'll let ya know what I decide....
-Mike
Old 05-09-2002, 02:33 PM
  #44
MaxSE98's Avatar
Originally posted by Screaminfast
bump.....
-Mike
hey Screaminfast just so you know, as long as the engine bolts in (it does) the rest isnt a big deal, for 1200 u could get a programmable efi setup. then you would be set electronically. if you do the work yourself youll save loads of dough. its not hard at all. btw that tranny you sold me had bad bearings in it. thanks so much for letting me know when i plopped down the 400 bucks for it
-pete
MaxSE98 is offline
Old 05-09-2002, 03:17 PM
  #45
192.168.1.1
gtr_rider's Avatar
Does anyone know where the stock numbers are? Say for bore and stroke and cams and other stuff?? If I can go to the companies with these numbers, they might be able to help me out in choosing what I would need to get??
Thanks,
Mike
3.66 inch bore by 2.89 inch stroke
gtr_rider is offline
Old 05-09-2002, 10:13 PM
  #46
Thanks....
I just contacted DPR racing in Cali too because I would like to have them do my headwork......I tried to contact TurboMax95, but he hasn't replied. I'm trying to find out how I can get a custom and thicker copper head gasket..hehe
Anyone know?
Thanks,
Mike
Old 05-12-2002, 05:47 AM
  #47
Ok, I need some ideas for an intercooler. Anyone have an Air to water intercooler here? I know my engine will be able to take a lot of Pressure, but at the same time I know the best I can do on the V2 is a 2.87" pulley. Anyone have some good ideas for a low pressure drop AWIC??
-Mike
Old 05-12-2002, 11:17 AM
  #48
'Trynna' is not a word
mtrai760's Avatar
I'm pretty sure he ended up using stock gaskets, couldn't find anyone to make them for a decent price.
Thanks....
Anyone know?
Thanks,
Mike
mtrai760 is offline
Old 05-12-2002, 12:47 PM
  #49
MardiGrasMax's Avatar
http://www.headgasket.com/
http://members.***.net/matchou/awicproj.htm
MardiGrasMax is offline
MAXSE5SPD
09-17-2022 04:00 AM
mvm062
11-30-2020 09:00 AM
A32goldylocks
09-02-2015 06:39 AM
MaximaDrvr
08-19-2015 08:20 PM
Quick Reply: Ok, i'm starting my engine project....
