where can i get a torque wrench cheap?
Old May 3, 2002 | 12:21 PM
Larcenist's Avatar
where can i buy a torque wrench for a cheap price. And is a torque wrench the same thing as an air impact wrench?
Old May 3, 2002 | 12:27 PM
sinewave's Avatar
http://www.harborfreight.com/cpi/cta...unction=Search
There are better, but none cheaper!
A torque wrench is NOT the same thing as an air impact wrench and don't let those tire monkeys tell you different.
Old May 3, 2002 | 12:38 PM
BioMaxDDS's Avatar
got my torque wrench at pepboys for $13.00
Old May 3, 2002 | 12:39 PM
Larcenist's Avatar
any recommendation on the amount of range of torque the wrench i purchase should have? I'm just planning on doing like minor repairs on my own... and maintance stuff as well as common car modifications.
Old May 3, 2002 | 12:43 PM
jim90gxe's Avatar
Are you sure you want a torque wrench? Or do you want a breaker bar?
Torque wrenches are used to tighten bolts/nut to specific values while breaker bars are used to loosen frozen bolts/nuts.
Breaker bars are good to have if you don't own an impact wrench.
Old May 3, 2002 | 12:46 PM
sinewave's Avatar
I would suggest that you get a racheting-click type with 1/2" drive and a range up to about 150ft-lbs. This will work for about 90% of the general mechanical work you will do.
Don't use it for low torque applications (<25ft-lbs); there is just too much leverage and too little sensitivity at those low ranges.
Pnjboyzz
Oct 7, 2015 10:47 PM
londonflu
40
Sep 25, 2015 09:11 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
pears
Sep 18, 2015 05:25 AM
