Where can I get the black goo that is used for sealing the taillights????
Old May 6, 2002 | 09:51 AM
NYCe MaXiMa's Avatar
What is that stuff called? Where can I buy it?
Don't ask what I need it for... My taillights will be taken out a few more times and I already got a lot of the goo off from the 2 attempts I had trying to do my clear my tails.. I don't want water in there and in case of anything, I'd like to have access to that stuff, plus if it's cheap and easy to find, why not get some.. just in case.
Anyone know what it is?
Where can I get it?
What else can I use as a substitute to seal the taillights to the body, sillicone maybe?
thanks.
Old May 6, 2002 | 10:01 AM
sbslacker's Avatar
Re: Where can I get the black goo that is used for sealing the taillights????
Where can I get it?
thanks.
It's just that....black silicone. It comes in a roll, and you have to heat is up a bit. You can also buy the squeezable kind at any hardware store. Just make sure to get the weatherproof variety and you are good to go. You're right, that stuff is messy.....and I won't ask what you need it for...
Old May 6, 2002 | 02:28 PM
Re: Re: Where can I get the black goo that is used for sealing the taillights????
thank you sir.
Old May 6, 2002 | 08:16 PM
Albertt's Avatar
I believe it's butyl sealant...nm
nm
Old May 6, 2002 | 08:19 PM
97BlackMax's Avatar
what does the silicone sealant come in?...like if i go to the hardware store, do i look for the waterproofing silicone sealant that can be used around the house and such, like caulk, or is there a specific type that is meant for use on cars?...thanks
Old May 6, 2002 | 08:40 PM
Albertt's Avatar
What you want is an adhesive >>
To bond the two halves (lens and housing) together. The black stuff you are looking for is an adhesive, softened with heat. The typical silicone sealant is not an adhesive, merely a environmental seal.
Talk to someone in the body work business, they'll know what to buy.
REDinLV
Aug 15, 2024 12:30 AM
mpbclutch33
Dec 26, 2015 11:11 AM
Redfox
Sep 28, 2015 10:41 AM
