Whining sound
Whining sound
Whining sound when the car is driving slow from stop. Coming from driver side front wheel in drive or neutral, changing pitch when driving faster. Starts after a 10-15 min of driving,sooner if hot weather. Checked brakes, not it. Looks like a cv joint or wheel bearing .I have 1999 se auto, 48000 mi, no mods.Any suggestions. Thanks.Andrei.
Andrei >>
I think I know what it is, but I don't know what it's called. Take off your wheel, then take off the big bolt on the middle of the whole brake assembly. take a mallet and hit the protruding screw thing in towards the car. Now look behind the brakes, and you'll see where the assembly seperated, and there will be bare metal. Take some high speed grease, and apply generosly. Put back together. If you have any questions let me know.
I really need to work on my terminology.
Re: Whining sound
A good way to check if that whining sound is engine related: go straight on an empty parking lot or road, roll down the window, shift into neutral, turn off the engine and keep rolling for 10-15 seconds. If the sound disappears then it might be your alternator. If the sound is still there then it's possibly your bearing or cv joint.
Udachi
Re: Re: Whining sound
Originally posted by AndyXXL
Andruxa. Most likely it's a wheel bearing. I had the same problem last summer.
Udachi
Udachi
Erik
Re: i have the same problem
Originally posted by tgonza1057
the sound is comming from my car too I have a 5sp and 94000 miles and also my car is leaking from the area you mentioned any ideas
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
