will a "Y" pipe take care of this problem?
Old May 15, 2002 | 05:11 PM
pjalst
What exactly does the "y" pipe conect to? The reason why I ask is ,I may have an exhaust leak in the manifold area. It's making a noise louder than usual. Do I have to get this leak repaired or will a "Y" pipe take care of this problem?
Old May 15, 2002 | 05:19 PM
CBass69187's Avatar
y pipe
It depends where the leak is. If you have a hole in your Y-pipe or a bad gasket, then a new y-pipe and gasket would fix it. However, it could be your cat, headers, etc.
Old May 15, 2002 | 05:22 PM
pjalst
Re: y pipe
I don't have a y pipe yet, That's why I'm asking
davis4005's Avatar
The y-pipe connects to both exhaust manifolds and the catylatic converter. I doub't that it will fix your problem unless one of the y-pipe gaskets is bad, there is a hole or crack in the pipe, or the flex section is shot.
Old May 15, 2002 | 06:31 PM
WaarrEagle's Avatar
Re: Re: y pipe
You have a stock y-pipe, it just has some restrictive cats on it. If yours has a hole in it and that is what is making the noise, a new one will fix it. Otherwise you have a problem somewhere else.
Old May 15, 2002 | 08:24 PM
pjalst
Re: Re: Re: y pipe
thanx
Mar 12, 2020 12:06 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Violator
Sep 9, 2015 10:14 AM
