FLIP FLOP YOUR TRUNK - Pictures and Instructions **ATTN** Nizmolee **ATTN**
Old May 25, 2002 | 09:46 PM
thebigsadler's Avatar
Before I even start this, I don't care if you think it is a rice mod, or if you think it is gay, or if you hate me and my car.. there are a few people out there who are interested in this stuff, so all you haters keep it quiet. Thanks much.. enjoy.
Picture of the Trunk as it sits completely stock
This is a closeup of the stock mounting of the trunk lid (2 bolts on each side that you remove that hole up the trunk lid)
Old May 25, 2002 | 09:55 PM
This is a picture of the hinge as it needs to be bent, I bought the hinge from Home Depot for $5.49 and had it bent at a hardware store after taking my trunk lid off and finding out what angles were needed
This is the back of the hinge attached to the trunk lid, I drilled 3 completely new holes for the hinge and used self tapping screws
This is a closer picture of the hinge attached to the trunk lid, same spot as the stock mounting piece
Old May 25, 2002 | 10:02 PM
This is where it get inventive and tricky, I used a simple locking latch from Home Depot for $2.49 that is used to slide lock fences or what have you, I drilled a hole in the arms of the trunk lid support and the sliding latch will slide the locking pin into the actual arm of the trunk lid support so that it will sit up normally. If you unlock, or unlatch the sliding latch so that it does not slide into the arm, you will let the trunk lid hinge down and sit "flip flop"..
This is also where the other side of the hinge gets bolted onto the mounting arm of the trunk lid, you can see it in the pictures, I used three screws for each and you can see how well the hinge is secured on there.
This is a picture of the holes drilled, 4 to secure the latch onto the trunk lid and then a bigger hole onto the mounting arm for the trunk lid where the latch slides into, you can also see the hinge fully mounted on the car.
Here is a picture of the latch slid into locking position in the arm and everything bolted down
Old May 25, 2002 | 10:12 PM
And my friends, that is all there is to it really, when you want the trunk to sit flip flop slide the latch out of the mounting arm and flip flop it.. just remember, you cant close the trunk when it is flip flopped.
Picture of the trunk sitting normal with the latches locked in place
Picture of the trunk flip flopped from behind the car
Picture from the side of the trunk flip flopped
Old May 25, 2002 | 10:21 PM
I guess this is my disclaimer of sorts.. i am not responsible for what you do to your car.
Depending on how far the hinge you buy swings around, your trunk may sit differently than mine does.. nothing extreme, but it just may be at less of an angle then mine. It is all about the bends you make, and it would be impossible to write out how I made the angles.. it's something you need to just look at and see.
If you do not mount everything correctly you may have issues closing the trunk because it will not line up exactly as it did when it was stock.. you can try and remount everything again or just finagle it into place when you close it or open it like i do.. mine is off a little bit to the left, but it doesnt bother me to shift it back and forth when I close the trunk, it sits the same when it is closed...
That is basically everything.. you need 10mm socket, metal drill bit set with a good drill, self tapping screws, 2 hinges, 2 latches, and a friend to help you out when you get tired of drilling or holding the trunk lid up on your back... and yes you need the winnie the pooh blanket to protect your car when you lay the trunk lid down and metal shavings go everywhere.
enjoy..
jason
Old May 25, 2002 | 10:23 PM
97BlackMax's Avatar
very nice mod man, i actually like it..and much better than all those ebay auctions tryin to rip people off
Old May 25, 2002 | 10:52 PM
CARIZMAX's Avatar
Looks like it came out good Jason. Good job!
Old May 25, 2002 | 10:56 PM
James92SE's Avatar
2 VE's are better than one!
Wow.....that's pretty impressive. I dont care what others say about it being "ricey" or whatever but I certainly think that looks pretty done cool. In fact, I think I'll try it on my car.
Old May 26, 2002 | 02:10 AM
SeaMAX's Avatar
Very nice mod and instructions. I'm not hating anyone but just want to be enllightened. I can't think of any reason, at this moment, why anyone would need a flip flop trunk. Is it for show, to better get things into you trunk, etc. Can someone enlighten me. Thanks.
Old May 26, 2002 | 06:12 AM
gtr_rider's Avatar
192.168.1.1
Want to do mine?
Thanks man, I was sleeping so blah, Ill put it up soon.
Write UP
Old May 26, 2002 | 07:23 AM
seamax, this is definitely an all for show mod..
Old May 26, 2002 | 07:43 AM
1HOTMAX's Avatar
wow
how many HP will this mod add to your ride?
jay/ i like the real duals!
Old May 26, 2002 | 07:59 AM
Vyrus's Avatar
thebigsadler...
You have one of the nicest Maximas I have ever seen - from the interior to the engine bay to the exterior to the trunk your car is sweet. The duals are definitely the hottest exhaust I've seen on a Max yet. BTW, great write-up.
-Cyrus
Old May 26, 2002 | 08:04 AM
DieselFX82's Avatar
Nice job. But what happens if it rains won't all the water go in the trunk?
Old May 26, 2002 | 08:22 AM
gtr_rider's Avatar
192.168.1.1
it closes like regular...
Old May 26, 2002 | 09:37 AM
Soon2BMaxed's Avatar
man that looks good as hell.....maybe one day when i can afford a nicer stereo i will do that to show it off. or maybe i'll do it for fun the next time i get bored.....hmmm
Old May 26, 2002 | 10:37 AM
metallic97gxe's Avatar
Master Will
looks cool and different so your trunk is like this or did you do for a how 2 then go back to stock?
it looks good though...
Old May 26, 2002 | 11:27 AM
DeRaNgEd's Avatar
I'm from Altimas.net and I am getting a 98 Max GXE in August. I wrote a very detailed write-up on how to do this.
It's on a 96 Altima but there is a 2% difference between the cars.
http://www.altimas.net/forum/showthr...threadid=33708
Old May 26, 2002 | 01:12 PM
Greg's2kGLE's Avatar
I have never seen that before and let me say it looks awesome. So all you do is unlatch that slide lock and it pivots? And if you leave the latch in, it sits like stock?
Old May 26, 2002 | 02:41 PM
DeRaNgEd's Avatar
The latches keep the trunk in place. Also, if you don't have the deadbots in, the trunk will not close properly. So you have to have them in the problem is that they tend to rattle if you have a system.
My one side rattles like a **** since I run 2,400 RMS.
Old May 26, 2002 | 03:04 PM
JoesMAX's Avatar
nice blanket Jay
Old May 26, 2002 | 06:32 PM
Nathan's Avatar
The trunk is bad@ss!!!!
Old May 26, 2002 | 07:55 PM
redmaxpa007's Avatar
i SeE what you did therE
nice...i been messin around with ideas on this... i was close to these instructions.. thanks man!!!
Old May 27, 2002 | 09:32 AM
Thanks for all the compliments out there..
yes i did leave this on my car, i thought about taking it off, but it's different and i like different.. plus people like seeing things move around and look weird.
Old May 27, 2002 | 02:20 PM
MaximaRider's Avatar
loox hot in person as well! and thanx again for the suspension help Finally got that bish airgunned down
Old May 27, 2002 | 06:56 PM
Neuhowse's Avatar
Nice mod. And btw, you have one of the nicest Max's on the org.
Old May 27, 2002 | 08:48 PM
thanks man.. i appreciate it.
arnaud - sorry again man.. we should take pictures of your car before you leave, i have a digi cam i can borrow from a friend.. let me know..
Old May 27, 2002 | 10:37 PM
N34JZ's Avatar
Needs non-Maxima Friends
cool
I just redid my trunk (setup) and Im probably gonna try this, how is it when it comes to rattleing?
Old May 28, 2002 | 06:59 AM
Re: cool
no rattles at all..
Old May 28, 2002 | 08:43 AM
James92SE's Avatar
If you guys are worried about rattles or happen to develop rattle(s) with this...
You could always just put a thin piece of rubber in between the metal/hinge, etc. That'd put a stop to any rattling.
I'm off to Home Depot
Old May 28, 2002 | 08:45 AM
the only rattle that could possibly occur because the hinges are tech screwed down so tightly is when the latch is unlocked and hanging there it could rattle back and forth, when it is locked it is so tight there is no room for movement.
good luck on the install james..
Old May 28, 2002 | 11:19 AM
piopremier's Avatar
looks real good man, i might have to try it also
Old May 28, 2002 | 11:36 AM
jhans114's Avatar
Nice set up with the trunk, maybe we'll see this on a 5th Gen...
Old May 28, 2002 | 01:47 PM
Vinipux's Avatar
by the way, how is the gas behind taillight project going?
Vinipux
Old May 28, 2002 | 03:58 PM
AndyXXL's Avatar
Vinipux
Old May 28, 2002 | 10:09 PM
as was mentioned about 3 weeks or so ago, I am home for the summer in New Jersey where I don't know anyone for anything here.. that is why minimal things are being done to my car while I am home.. when I come back to florida in the fall I should have this done ASAP along with full repaint and some other body work.
Old May 29, 2002 | 04:20 AM
AndyXXL's Avatar
Are you going to NJ meet on June 9th?
Old May 29, 2002 | 08:29 AM
yes sir... hopefully i can jump in a caravan.. such a boring ride alone..
REDinLV
Aug 15, 2024 12:30 AM
bigfrank
Oct 1, 2015 12:51 PM
