Clutchnet Six Puck Pictures
Old May 29, 2002 | 08:16 PM
MardiGrasMax's Avatar
I installed a new clutch, a clutchnet six puck sprung hub disc and heavey duty pressure plate. Yes I know the six puck is harder on the drive line but I am hoping that the sprung hub keeps the stress under control. It was very chattery at first but as I have put some miles on it it has smoothed out quite a bit, its very livable. I have 50 mile left to go in the break in period, after that I will let you guys know how it feels. Thanks to Sleeper for the hook up on this one!
Old May 29, 2002 | 08:18 PM
Pressure Plates
Old May 29, 2002 | 08:37 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
1.5, 3, 4.5, 6
that clutch looks sick too, post up your new tires too
-steve
Old May 30, 2002 | 04:51 AM
Confused's Avatar
Permanent Maxima.org Resident
Old May 30, 2002 | 05:42 AM
madmax2k's Avatar
I think you will find that clutch to your liking. I used the same basic design, but with a 4 puck disk, and a stock pressure plate on my Turbo Dodge. I ran over 400 ft lb through it and it didnt slip! I even tried riding the clutch hard to get it hot and it bit even harder. This clutch material loves heat.
In the bang for the buck department, this clutch disk cant be beat. I paid $145 for the disk direct from Clutchnet.
Old May 30, 2002 | 06:12 AM
Thanks for the input Larry!
The clutch does feel much better after its been drive and warmed up.
Old May 30, 2002 | 07:15 AM
Whitemax's Avatar
Disco Biscuit
How does the pedal feel with this clutch? Once I got my Centerforce DF, the pedal got really soft feeling over stock. I was hoping it would be a little stiffer.....
And the clutch ony cost $145?????
Old May 30, 2002 | 07:59 AM
145 for just the disc, not the disc and pressure plate.
I paid 461 shipped, I also needed to get a TO an Pilot bearing ~$45
The pedal feels a bit stiffer than stock.
The ACT feels much stiffer.
Old May 30, 2002 | 02:57 PM
don't they like make clutches to order kinda?? clutchnet, could they get me a clutch for my 2k2??
-steve
Old May 30, 2002 | 04:04 PM
papasmurf's Avatar
Honda Convert!
How does this thing compare to the ACT extreme street disc and pressure plate?
Bruce
Old May 30, 2002 | 07:57 PM
It will hold more power than tha ACT.
It is not really for street use.
It wont last as long as an ACT
Its got chatter some times, so its hard to drive smoothly.
Old May 30, 2002 | 08:01 PM
-steve
Yes I'm sure they could, they would just buy a stock pressure plate and heat it and modify it to give 30-40% more pressure. I would imagine that they would also have to buy a stock disc to use as a template to make you up a better one. Give them a call...
Old May 30, 2002 | 08:06 PM
gtr_rider's Avatar
192.168.1.1
Center Force is doo doo
Old May 31, 2002 | 02:05 AM
papasmurf's Avatar
Honda Convert!
So mardigras do you think i should sell my act and go with the clutchnet cause im going to be installing my turbo here shortly and also how do you think this will work with a lightend flywheel or aftermarket flywheel?
Bruce
Old May 31, 2002 | 05:38 AM
If it aint broke dont fix it
Until the ACT starts to slip I wouldnt sweat it.
I think a light weight flywheel would make it harder to drive.
I stayed with a stocker.
bigfrank
Oct 1, 2015 12:51 PM
MichMaxFan
Sep 30, 2015 09:18 AM
