Look what came in the mail today?
Old May 30, 2002 | 03:12 PM
1MAX2NV's Avatar
Rest of the pictures are here. I'll add some more pictures after they are on the car.
http://imageevent.com/1max2nv/warpsp...frameconnector
Old May 30, 2002 | 03:16 PM
1MAX2NV's Avatar
I guess I have a week until the NE meet to get them installed.
Old May 30, 2002 | 03:21 PM
gtr_rider's Avatar
192.168.1.1
What is that supposed to be?
Just read the image path!
Old May 30, 2002 | 03:23 PM
metallic97gxe's Avatar
Master Will
they are Warpspeed subframe connectors....
Old May 30, 2002 | 03:24 PM
sbslacker's Avatar
SFC's...
How heavy are those things anyway? Hollow or solid?
gtr_rider's Avatar
192.168.1.1
yes...
speednsound007's Avatar
I have no idea....subframe connectors?
PJ
Old May 30, 2002 | 03:34 PM
Master Will
PJ
more chassis stiffening and frame support....
Old May 30, 2002 | 03:36 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Did you paint them red or powdercoat them red?
SFC's are hollow.
Old May 30, 2002 | 03:40 PM
Lordrandall's Avatar
Has the red trend gone too far?
Old May 30, 2002 | 04:01 PM
Yea I know what subframe connectors are...All the posts before it were not there when Ir ead the thread, I must not have reloaded the page recently or something.
Hey I guessed right though! Go me!
Old May 30, 2002 | 04:10 PM
papasmurf's Avatar
Honda Convert!
Hey Tony, have fun with the SFC's once you get them on. I talked to the boys at Warpspeed and they said these things are amazing.
Bruce
Old May 30, 2002 | 04:31 PM
1MAX2NV's Avatar
Powdercoated
SFC's are hollow.
Old May 30, 2002 | 06:20 PM
redmaxpa007's Avatar
i SeE what you did therE
Originally posted by 1MAX2NV
Powdercoated
did they come powder coated?
Old May 30, 2002 | 06:32 PM
dblrr900's Avatar
A) Do they have these bad boys for 5th Gen?
B) How far back did they set you back?
Old May 31, 2002 | 04:20 AM
it is like 200 for the stage one and stage 2 kit..
Old May 31, 2002 | 05:59 AM
1MAX2NV's Avatar
They came powdercoated. I believe I got the first set of powdercoated version.
Old May 31, 2002 | 06:02 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
when jeff enters the thread...yes
Old May 31, 2002 | 06:03 AM
HEY!!!
chris
Old May 31, 2002 | 06:24 AM
Y2KevSE's Avatar
What's wrong with red? I think the red SFCs work well with Tony's car since it is a show car also.
Old May 31, 2002 | 06:39 AM
1MAX2NV's Avatar
I'm thinking about putting my car up on two ramps on one side for HIN. To show off the SFC, but it might be more trouble than it's worth
Old May 31, 2002 | 06:49 AM
DanNY's Avatar
Ad·min·is·tra·tor
mirrors?
damn..if you're going to jack up one side of the car for show then u should've got them chromed
Old May 31, 2002 | 06:52 AM
lcf's Avatar
lcf
how much you expect to get charged for having these welded on?
Old May 31, 2002 | 06:54 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
ahhh...you're in the AC show? suhweet!
Old May 31, 2002 | 07:21 AM
ny96max's Avatar
Chromed versions would be alot showier
Ant
Old May 31, 2002 | 07:22 AM
Y2KevSE's Avatar
Polished would look nice also. Hehehehe
Old May 31, 2002 | 08:32 AM
Matt93SE's Avatar
STFU n00b!
hope you don't drive over anything bigger than a speed bump between install and show.. that purdy red powdercoat will come right off.
My SFCs are scratched to Hell and back, but I didn't get them powdercoated. they also rub against my cat anytime I hit a bump or on hard cornering. hafta bend them back down next time I get under the car.
But yes.. red powdercoat is purdy..
What are you going to do with it after they're welded on? krylon over the weld marks? (proabably your only option, but make sure you sandblast the rust off, or the paint will peel right off)
Old May 31, 2002 | 09:22 AM
Vinipux's Avatar
looks good man, can't wait to see them on your car
Old May 31, 2002 | 02:49 PM
Dave B's Avatar
Not DAVEB the parts guy
Looks very nice, but be very aware that if you have a low drop (2+") the Stage II will bottom out and you will loose that pretty paint. I watched BSwithTF (Travis) bottom out his GXE with Sprints and the Stage II while pulling into the dyno pit. There was barely an incline either. I've got a 2" drop and my Stage Is have about 4" of ground clearance at their lowest spot. BTW, I sprayed my SFCs with some undercoating to keep them from rusting.
Dave
Old May 31, 2002 | 03:38 PM
Chinkzilla's Avatar
Dave
Granted he'll bottom out and get them scratched, however it's not going to peel and chip like normal paint. I believe powder coating is a process in which you actually bake stuff onto the surface of metal so it bonds with it. Same process as powdercoating rims. Pretty hard to get off i think.
Old May 31, 2002 | 05:13 PM
KLOOGY's Avatar
L33t BMW Drivah
Im not sure if I saw an answer, are they available for the 5th gen ??
Old May 31, 2002 | 11:57 PM
TurDz's Avatar
Those were my thoughts exactly. That's why powercoating is such a special and expensive process, right?
Old Jun 1, 2002 | 01:07 AM
Y2KevSE's Avatar
http://boostedmaximas.com/y2kevse/im...me_connectors/
howardis
Dec 11, 2019 06:10 PM
Forge277
Jun 13, 2016 09:26 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
