EGT,Boost,Air/Fuel gauge intall???
Old May 30, 2002 | 07:22 PM
20thdriven's Avatar
Is this a DIY install or am i better off going to a shop? and how much would they charge? I'm installing the V2 myself but don't know jack about electrical wiring.
If any of you have tips/info on the wiring I would appreciate anything.
Thanks. I have a pod off an old eclipse.
It's a V2 on an AE
Derrick
Old May 30, 2002 | 08:18 PM
max'n out's Avatar
Ok let me get this...You cant' do electrical wiring but your going to hook up the v2????
Old May 31, 2002 | 01:55 AM
papasmurf's Avatar
Honda Convert!
The V2 isnt that hard to my knowledge especially if you use these directions
By the way youll have to cut and paste this link. But as for the guages there should be directions with them if not i think there is plenty of people to help you here on the .org
My advice is not to pay some a$$ your hard earned $$$ to do something you are capable of doing. Just jump in and get your hands dirty the worst thing you can do is not hook it up right so you have to do it agian untill you do.
Bruce
Old May 31, 2002 | 04:02 PM
20thdriven's Avatar
yeah, i can't figure out why i'm more confident on the V2 install either. but thanks for the link papasmurf... is it true that the auto meter EGT needs an additional probe? how much?
Max'n out, what are your track numbers with your setup? i'll be running the 3.33
Old May 31, 2002 | 04:18 PM
bullseye's Avatar
The Autometer EGT does require the separate purchase of a probe. I got the #5244 from Summit Racing for about $100.
Old May 31, 2002 | 04:44 PM
mtrai760's Avatar
'Trynna' is not a word
My autometer EGT came with a probe...
Old May 31, 2002 | 04:59 PM
JAY25's Avatar
The power for the EGT you can get that from on of the lighter wires and ground it to something metal. The probe you will have to remove the manifold heat cover and drill a nice hole for the probe.
Old May 31, 2002 | 06:31 PM
AntGVR4's Avatar
so did mine, Autometer Pyrometer, gauge and probe for 113 shipped. The gauges are easy to install.
Ant
Old Jun 5, 2002 | 01:47 PM
dashingMax's Avatar
I got you covered...
I have done A/F gauge & I can do one for you too...
I can setup the wiring for the EGT & Boost gauge. I am nervous about drilling, so I will let you open thge heat sheild & drill a hole in your exhaust manifold... I will run the probe into your engine bay...
Don't sweat gauges... It is time consuming...but easy.
Worry about the SC
Old Jun 5, 2002 | 01:53 PM
1MAX2NV's Avatar
It all depends on the model of the gauge. Only certain EGT works with certain probes...etc. Kinda complicated. Just pick up an autometer catalog and it's all in there.
Old Jun 5, 2002 | 01:56 PM
Jeff92se's Avatar
I'm needing a caw
Why EGT and a/f? I would forgo the a/f(unless it's one of those expensive accurate ones) and maybe go with a fuel pressure guage instead?
Old Jun 5, 2002 | 02:01 PM
The New CLIMAX's Avatar
Good point, I have boost, EGT, and Fuel press. I have never been to fond of a A/F unless you have turbo and adj the boost freq. But if you have S/C and you dyno tune all should be good.
Old Jun 5, 2002 | 02:27 PM
dashingMax's Avatar
If I only had room for 2 gauges, I would go with EGT & fuel pressure...
unless of course, you guys tell me otherwise
Old Jun 5, 2002 | 03:35 PM
CBass69187's Avatar
gauges
If you are FI, you would prolly want a boost for sure and then the other is your preference.
My .02
Old Jun 5, 2002 | 04:31 PM
20thdriven's Avatar
I returned the A/F leaving me with
-Boost
-Oil pressure
-EGT
I'm only running an SC no N2O, so what is the importance of fuel pressure besides to make sure that there is some? If EGT goes too high then I'm lean, same thing reversed... isn't that enough to monitor fuel? I just don't want too many gauges. Thanks for all the input guys! anyone know track #'s with 3.33 on a 5th gen 5spd?
Old Jun 5, 2002 | 07:40 PM
BBaker025's Avatar
Old Jun 11, 2002 | 07:41 PM
Tanman's Avatar
-Boost
-Oil pressure
-EGT
Someone going to answer his question? What is the fuel pressure gauge good for if you already have the EGT?
Old Jun 11, 2002 | 10:06 PM
CBass69187's Avatar
I think FP is good from a tuning perspective if you plan on doing a lot of tuning with fuel. Since you are FI, you could put a gauge under the hood even, since you will on a set fuel curve. If you were NO2, FP is prolly mandatory IMO.
My .02
Old Jun 12, 2002 | 05:54 AM
Tanman's Avatar
-Boost
-Oil pressure
-EGT
How much did you pay to get all these gauges installed?
Old Jun 12, 2002 | 08:27 AM
CBass69187's Avatar
Install cost will vary from shop to shop. I think he could install them himself if he can handle the SC install. Gauges are time consuming to install but not any more difficult than a SC install.
Old Jun 12, 2002 | 02:28 PM
20thdriven's Avatar
Boost ~50
Oil Pressure ~50
EGT~100
EGT Probe ~100
Installation ~200
Old Jun 12, 2002 | 02:51 PM
20thdriven's Avatar
BTW
all 3 are Autometer Phantoms
I'm using a 1 single and 1 double 4 gen pod on my 5th gen. the fit is horrible so i have to resort to some fiber glass or bondo. i'll post pics.
Old Jun 12, 2002 | 05:27 PM
Tanman's Avatar
Re: $$$
Boost ~50
Oil Pressure ~50
EGT~100
EGT Probe ~100
Installation ~200
Wow, $200 to install all the gauges? Not a bad price. Hopefully some place in Houston will be as inexpensive.
Old Jun 12, 2002 | 10:13 PM
CBass69187's Avatar
install
Heres a link if anyone is interested:
http://vbxmaxima.8m.com/gauges.html
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
MichMaxFan
Sep 30, 2015 09:18 AM
RWCreative
Sep 21, 2015 11:01 AM
