99 max = can't reset ECU?
Old Jun 1, 2002 | 04:18 PM
costcowholesale's Avatar
I got the CEL light because when I tried to install my intake which didn't worked (first attempt now its ok) because the MAF sensor was unpluged, now I took the piece beside the accleartor pedal apart & tried to reset ECU, I poked thru that plastic hold that tells u how to turn the ecu screen, but theres NO screw in it wtf(even used flash light to check) then I checked another member's 4th gen 97 max & u can see the screw inside it, so whats with mine? the 99 ecu is the same as teh 00+ ecu & cannot be resetted? should I unplug battery overnight? please help!
Old Jun 1, 2002 | 06:38 PM
Mizeree_X's Avatar
Getting back to his roots
Re: 99 max = can't reset ECU?
Disconnect the battery for awhile.....that should do it....hope you're not too attached to your pre-set radio stations
Old Jun 1, 2002 | 06:40 PM
Re: Re: 99 max = can't reset ECU?
I just did that, hopefully it'll go away, i'll plug it back in tomorrow
Old Jun 2, 2002 | 07:03 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
What was the build date of your car?
If it is 02/99 or later (maybe 03/99 I'm not sure), then SPECULATION is it's a 2k+ ECU and you're screwed.
My 99 was built in 03/99 and I haven't had the heart to look and see on mine.
Another indication is if you have those stupid flanges on the top of your strut towers on the driver's side that makes puttin in older rev. (i.e. not for 5th gen) FSTBs require a hacksaw and lots of patience....
Old Jun 2, 2002 | 08:16 AM
no I don't have that bracket thing that blocks the FSTB, I got aFSTB in there without problem.
mine was one of the first 99, I took the car home october 30th 1998 so it was build earlier than this.
I unplugged teh battery over night, I'll see what happens when I plug it back in an hour or so. If the CEL is still on what can I do?
(its been unplugged for over 12hrs)
Old Jun 2, 2002 | 08:24 AM
I can see a hole in there but I don't think theres a screw in there, also do I leave the car in "on" position when I reset the ECU? the instruction I've read just say turns it clockwise wait then turn back & repeat doesn't say if the key should be in it or not when doing this
Old Jun 2, 2002 | 08:39 AM
redmaxpa007's Avatar
i SeE what you did therE
drop an elbow on it...
there is a screw there..
yes.. the car should be on... at least power should be applied to the accessories
Old Jun 2, 2002 | 08:44 AM
thanks! I kept turning the screw clockwise then counterclockwise yesterday when the keys were in my pocket because none of hte instruction said leave it in "on"
Old Jun 2, 2002 | 08:50 AM
hehe
power has to be applied to the ecu so it can reset itself...
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
220k+ A32
Sep 22, 2015 03:08 PM
QueensMAX
Sep 15, 2015 04:14 AM
lux97Max
Sep 11, 2015 01:12 PM
Colossus
Sep 9, 2015 05:46 AM
