Effects of weight on 1/4 Times
Last Tuesday I went to the track and a friend was watching us race. He had never been in a run down the track and no one else wanted to take him, so I offered. Well I ran a 15.6 with a 2.3 60' with him in the car. He weighs probably 180 lbs at the most. Next run, I ran by myself and pulled off a 15.1 with a 2.3 60'. There was nearly a 3 mph difference between the runs also.
In conclusion, 1 passenger in the car(180 lbs) will ADD nearly .5 to your 1/4 time.
Originally posted by pro
Yep, this was discussed earlier and I think a formula came up that said for every 100 pounds you have you lose 15 HP.
Good Luck,
Paul
Good Luck,
Paul
3300/222=14.864
3400/222=15.315
Originally posted by MAX2000JP
Thats sounds about correct if you play with lbs/hp ratios.
3300/222=14.864
3400/222=15.315
3300/222=14.864
3400/222=15.315
Re: Effects of weight on 1/4 Times
If you would have done like 2, 3, 4 or more runs with and without the passenger, I would believe your conclusion, but until then, I'm going to have to question .5 off a quarter mile time for a 180 pound weight reduction.
Re: Re: Effects of weight on 1/4 Times
Originally posted by guitaraus
You ran twice, once with and once without a passenger, correct? I don't think you came any conclusions...your logic about the passenger is like me saying "It was sunny outside, I came inside and changed my clothes, and then it was raining outside. In conclusion, changing clothes causes rain."
There have been several threads about this recently. When I use one of those horsepower formulas, I get about .15s reduction (or gain) for each 100 lb added/removed from the car. However, just like you, when I ran with my ~200lb friend, I had .6s added to my clock! I agree that 180 lb would add .5s to yours.
MatthewsMaxima
Sep 11, 2015 03:21 AM
Justin Kroll
Sep 2, 2015 11:06 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
