BKR6E lock and loaded...
Old Jun 28, 2002 | 05:47 PM
//M5'ver
who wants some
Old Jun 28, 2002 | 05:57 PM
BriGuyMax's Avatar
I can pick them up any time I need them at my local auto parts store.
Old Jun 28, 2002 | 06:19 PM
//M5'ver
they costed me $2.50 at the dealership .. i got ripped
Old Jun 28, 2002 | 09:34 PM
Nismo87SE's Avatar
Why are you running BKR6E's, because those are stock SR20DE heat range plugs . BTW I paid $1.75 at napa for them .
Old Jun 28, 2002 | 09:38 PM
//M5'ver
1 step colder copper plugs for us.. or stock plugs for the 89 GXE
Old Jun 28, 2002 | 09:39 PM
redmaxpa007's Avatar
i SeE what you did therE
well i do not want none...
Old Jun 29, 2002 | 10:34 AM
BriGuyMax's Avatar
This is what happens to a BKR6E-11 with a 100-shot and an injector that freezes up.
http://community.webshots.com/storag...2XAtaAX_ph.jpg
(copy link to new window)
Old Jun 29, 2002 | 10:40 AM
//M5'ver
isn't that more to do with fuel pressure too high than plug?
Old Jun 29, 2002 | 10:41 AM
Vyrus's Avatar
I've seen worse though.
-Cyrus
Old Jun 29, 2002 | 11:52 AM
BriGuyMax's Avatar
yes...I just though it interesting that you were talking about the NGK coppers...and I had a pic of my NGKs from my old motor.
Old Jun 29, 2002 | 12:50 PM
//M5'ver
thats funny.. the time when i killed dmbmaxima to NJ and kick his a$$ all the way.. my plug was worse than that.. it had no tip at all.. but that was stock heat range on 100 shot and i was hesitating like crazy going home
Old Jun 29, 2002 | 04:30 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
wait till i get my 150 shot, i wub you. and i was stock, i wouldn't be proud
Old Jun 29, 2002 | 07:16 PM
BriGuyMax's Avatar
and you still have all your piston rings intact??????
Old Jun 29, 2002 | 10:25 PM
mattC's Avatar
yea... your car was not doin' too well...
- M
Old Jun 30, 2002 | 03:11 AM
//M5'ver
yup
Old Jun 30, 2002 | 07:05 AM
deezo's Avatar
It was an incredible sight to see.
Old Jun 30, 2002 | 07:22 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
BKR5E-11s in my VG and stock VQ now.
Cost: $1.40 each.
Old Jun 30, 2002 | 10:54 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
No pics... no turbo.
Old Jun 30, 2002 | 11:25 AM
//M5'ver
Originally posted by bill99gxe
BKR5E-11s in my VG and :wall-: stock VQ :wall-: now.
Cost: $1.40 each.
i can't seem to find those since dealerships are too stupid to go by plug names.. i did some back tracking on courtesy nissan site to see what car it goes to.. and it goes to the VG engine.. however they also list the BKR6E for the VG also... so luck of the draw.. i got the 6E..
Old Jun 30, 2002 | 03:03 PM
bill99gxe's Avatar
Yeah, it's weird. The BKR6E and BKR5E seem to have several possible part numbers. Here are two I know work:
22401-50Y05 BKR5E NGK V-Power
22401-50Y06 BKR6E NGK V-Power
Ultimate Z tried to send me the BKR6E, but when they read the part number, I realized Nissan made a cold/standard plug distinction with the last digit in the part number for the BKR5E/6Es.....
V-Powers add at least 30 or 40 ponies......
Old Jun 30, 2002 | 03:53 PM
//M5'ver
can i use that number at the dealership?
Old Jun 30, 2002 | 07:33 PM
bill99gxe's Avatar
Yep, just ask for 6 of them.
Parts database search on nissanparts.cc and nissanautoparts.com confirm those numbers as being real, and of course the 6 now in the VQ and other 6 waiting to go in my VG........
Old Jun 30, 2002 | 07:36 PM
AznWontonboy's Avatar
No pics... No fiance/girlfriend/wife.. j/p
Old Jun 30, 2002 | 07:40 PM
bill99gxe's Avatar
No knowledge, no use of search function.
Old Jun 30, 2002 | 08:11 PM
//M5'ver
cool i am off work on Wens.. i will take a trip down there..
thanks Bill
Old Jul 1, 2002 | 06:06 AM
bill99gxe's Avatar
thanks Bill
Odd, but this is the first time the part number(s) above have been mentioned here.....now I've completely forgotten where I found them....
Old Jul 1, 2002 | 08:27 AM
//M5'ver
probably that thread that got deleted in the 4th Gen Forum
Old Jul 1, 2002 | 08:34 AM
bill99gxe's Avatar
No, I have a paper copy of that one.
Just no time to re-do all that with the Oil Analysis stuff.
I have a part number listed in that original sticky FAQ that is supposed to be for the BKR5E, but it ends up being for a platinum plug........I do also have the BKR5ES standard copper plug, but why turn down the extra 30 or 40 ponies with the V-Power copper plugs....
Old Jul 1, 2002 | 08:40 AM
//M5'ver
i didn't know V Power plugs started with "B" i thought they started with "Z" .. when we were changing my Aunts plugs on her 94 Accord it called for "Z" type plugs and they were V Power..
Old Jul 1, 2002 | 11:05 AM
Lordrandall's Avatar
I've got a pic of them together....
Old Jul 1, 2002 | 03:56 PM
ryz's Avatar
ryz
so which one to use for stock max 6e or 5e or 5e-11s
Old Jul 1, 2002 | 04:01 PM
Jime's Avatar
Re: ???
5e-11s
Here's a typical NGK spark plug part number: BKR6E-11.
A quick run down of the part numbers. Each letter or number has significance in the NGK part number, but the same letter may hold a different meaning depending on where it is placed:
B Thread diameter = 14 mm
P Construction = Projected Insulator Type
(K) Construction = Hex size 5/8 in, projected tip
R Construction = Resistor Type
6 Heat Rating Number = 2 Hot -> Cold
E Thread Reach = 12.7 mm
S Firing End Construction = Standard 2.6 mm diameter center electrode
(VX) Firing End Construction = High performance platinum
(K) Firing End Construction = 2 ground electrodes
(N) Firing End Construction = Special side electrode
(-11) Gap Width = 1.1 mm (0.044 in)
Old Jul 1, 2002 | 07:36 PM
ryz's Avatar
ryz
you are tha man thanks for the reply .......where did you get this info though ,I would like to have the source
Old Jul 1, 2002 | 08:16 PM
Jime's Avatar
http://www.extrememotorsports.com/plugfaq.htm
James92SE
142
Jan 2, 2024 09:23 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
ajahearn
Sep 19, 2015 03:03 PM
johnaschon
Sep 14, 2015 04:29 PM
