How do I roll my fenders?
I just found out that when I have people in my back seat and hit a bump, my rear tires are rubbing ever so slightly in the rear. Do I just need to get the lip of the fender bent up so it doesnt rub the tire?
Re: How do I roll my fenders?
Look at the inside of your rear fender, and see if you can tell where it's rubbing. If it's only on the folded over part of the fender material you should be fine with it rolled.
Take a nice round piece of metal, the bigger the better for a smooth roll, and put it beween your tire and fender. If your car is lowered too much you might have to jack it up a tiny bit, but don't have the tire off the ground. Then just work it back and forth till you bend that part of the fender back a bit. Don't press to hard or you will bend something you don't want to.... doh.
Luck!
Luck!
Re: Re: How do I roll my fenders?
Luck!
Luck!
Re: Re: Re: How do I roll my fenders?
Originally posted by gtr_rider
Please, use a *wooden* bat so you dont scratch the paint off*
Re: Re: Re: Re: How do I roll my fenders?
I guess you could use a wood bat as well. I was pretty carefull, but piece of mind is good too.
Luck!
Luck!
Originally posted by Whitemax
And how do you heat the paint???
HerpDerp1919
09-29-2015 02:02 PM
