RVM Racing Lightened Crank Pulley's - Group Deal
Old Jan 7, 2003 | 04:58 PM
  #81
ryanmc's Avatar
Re: Wow!
Originally posted by ardika
Seems to me that I am not the only one who was having a rough day at that time, eh?
I could concur that you guys were pretty intensed when I was there standing in front of your door.
No problem, I am glad that you solve the problem before the new year coming. I don't know your name, but I will give you guys a call on Monday morning next week.
If Fabio is no longer in the circle, so be it. I'll just have to find a reputable shop to install the pulley here in Milwaukee/Chicago area.
Thank you for the explanation,
Armand
wow half a i was standing out there too with him
Old Jan 7, 2003 | 05:07 PM
  #82
ardika's Avatar
Re: Re: Wow!
Oh! That was you with the green Jetta? Well, now we know what's happening inside at that time.
Old Jan 7, 2003 | 05:42 PM
  #83
ryanmc's Avatar
Re: Re: Re: Wow!
nah i was justkidding tryin to get a pulley for half
Old Jan 8, 2003 | 04:07 PM
  #84
Triple8Sol's Avatar
I miss the .org!
Anybody with a 2002-2003 ordered and/or installed this RVM UDP? I just want to make sure it will fit, and also of exactly what belt/s to get, and from where?
Old Jan 8, 2003 | 04:14 PM
  #85
dohccivicna1250's Avatar
On 2002-up
The owner of Frankencar put it on his 2002 max, he was very happy with it. There is a post detailing everything on it on the org,
Old Jan 13, 2003 | 07:26 PM
  #86
Triple8Sol's Avatar
I miss the .org!
Found it, thanks. How many of these do you have left now?
Old Jan 18, 2003 | 06:16 PM
  #87
y2kse's Avatar
Let's cut to the chase . . .
Is it worth spending $80.00 (or any amount of money, for that matter) to purchase a UDP? I've read through this entire thread and I've yet to find a single post that indicates a performance increase as a result of installing it. Actually, the only hard information I was able to find indicated a performance DECREASE as a result of installing it. And on top of that, it's something of a PITA to install.
What I'm looking for are FACTS as opposed to opinions. I'm not interested in purchase decision justifications based on esoterics ("gee, it's a whole lot prettier than the stock pulley") or emotional pleas ("it's got to be worth it cause I spent my money on it and I'm no dummy").
Thanks in advance.
Old Jan 18, 2003 | 06:53 PM
  #88
emax02's Avatar
Re: Let's cut to the chase . . .
Originally posted by y2kse
Is it worth spending $80.00 (or any amount of money, for that matter) to purchase a UDP? I've read through this entire thread and I've yet to find a single post that indicates a performance increase as a result of installing it. Actually, the only hard information I was able to find indicated a performance DECREASE as a result of installing it. On top of that, it's something of a PITA to install.
Thanks in advance.
Pulley Group deal HATER #1
Bruce tell me, exactly how many pulley group deals are you gonna have to attempt to destroy before your happy? Have a problem with UDP's? Want to learn more about them? Make your own post or do a search.
Old Jan 18, 2003 | 06:59 PM
  #89
y2kse's Avatar
Forum rule number one. Never do battle with a moderator.
I'm just trying to help some Org members make reasonable purchase decisions, emax95. But it doesn't surprise me that some individuals might take offense at being confronted with the facts. FYI, I've researched this subject pretty thoroughly. So I'm fairly well acquainted with the facts. I'm open to new information, however.
Got some?
Old Jan 18, 2003 | 07:11 PM
  #90
emax02's Avatar
I'm just trying to help some Org members make reasonable purchase decisions, emax95. But it doesn't surprise me that some individuals might take offense at being confronted with the facts. FYI, I've researched this topic pretty thoroughly. So I'm fairly well acquainted with them.
This is not the first time you shared your "facts" in a pulley group deal though.
Old Jan 18, 2003 | 07:17 PM
  #91
emax02's Avatar
Got some?
I see you changed your reply.
New information? The fastest all motor maxima uses a UDP, that should tell you something
Old Jan 18, 2003 | 09:08 PM
  #92
sterling99SEL's Avatar
Thanks in advance.
I think I posted this earlier in the thread, but I could tell that my car is stronger on the low-end after installing the pulley. It's an Auto and seems to shift at lower revs under the same driving conditions - like the engine doesn't have to try as hard. Haven't kept a close check on the gas mileage before and after so can't comment on that. Also haven't been to the track yet with the pulley...
Old Jan 18, 2003 | 09:26 PM
  #93
y2kse's Avatar
Hmmmm. Did the owner of the fastest all motor maxima happen to dyno his maxima before and after he added the UDP? What were the results?
Old Jan 18, 2003 | 09:28 PM
  #94
y2kse's Avatar
Re: Re: Let's cut to the chase . . .
I assume the UDP is the only mod you've added since the last time you were at the track. If so, please keep us posted on your next track results. Thanks.
Old Jan 18, 2003 | 09:45 PM
  #95
emax02's Avatar
Yes he did, from the dyno before the UDP he did 214.6 WHP, the next dyno was done and a UDP was added,he put down 229.2 WHP. Did I mention a Y-pipe was added on his car too?
Old Jan 19, 2003 | 07:22 AM
  #96
Larry's Avatar
Thanks in advance.
I have been using UD pulleys for years. I measured an improvement of .2 on an 88 5.0 Mustang that I installed ASP pulley's. This Mustang had an air pump and of course a water pump pulley that our Maxima's do not have so there is not as much gain to be had on our Maxima's. I later installed ASP,s racing crank and got .3 improvement. Fact is when you slow down an accessory by driving it slower it doesn't take as much hp to turn that accessory. One added benefit is accessory longevity. If you turn your alternator, ps and ac slower they will last longer and also the rpm that our engines turn it sure might help to eliminate damaging the alternator at high engine rpm. These Maxima's do turn some rpm.
On my 98 Camaro I got .1 improvement and about 8 hp with the crank pulley.
I have installed an underdrive on my Maxima and I dynoed 215 hp before and 220 hp after. However, I did measure about 6 pounds less peak torque. Maybe a quirk, I don't know. The dynos were done on different days so who knows. I'm just reporting what the dyno said.
I do recommend the UD pulley's just because I have seen such good gains on other cars I have owned. Whether you can measure it or not the gains are there!
Old Jan 19, 2003 | 07:23 AM
  #97
y2kse's Avatar
Very interesting, emax95. But I'm not quite sure I have the facts straight. Are you saying that he gained 15 hp with a UDP and a Y-pipe or with the UDP alone? If it was just with the UDP, I'd find that a bit of a stretch. And if it's with the UDP and a Y-pipe, I'd attibute most if not all of the gain to the Y-pipe.
Most importantly, however, is the fact that he has not attempted to explain ][ 35's experience. Why do you suppose he gained performance with his UDP when ][ 35 actually lost performance with his?
Old Jan 19, 2003 | 06:39 PM
  #98
NiNe7-Gxe's Avatar
i believe he chipped some teeth in the flywheel during the installation.
site taking too long to load, but from what i read a month ago that was it. (or was it another member?)
Old Jan 20, 2003 | 05:03 AM
  #99
I chipped a couple teeth on my flex-plate when trying to get the main pulley bolt off.
Long story short, I got a used flexplate for $65 and did the work myself. Was fun!
Old Jan 20, 2003 | 12:45 PM
  #100
Jime's Avatar
I just ordered one of these pulleys around 1PM today and already have the FEDEX shipping #.
Hope it works as well as the service.
Old Jan 21, 2003 | 05:42 PM
  #101
costcowholesale's Avatar
so you paypaled him $88 american? do u think u'll get charge any duty fees? do u need belts for this?
Old Jan 21, 2003 | 05:50 PM
  #102
Jime's Avatar
Dennis, $87 US and you do need belts. They are around $40 Cdn but most folks need new belts anyway.
PS Got mine today at 11:42 AM. Great service. Thanks
Old Jan 28, 2003 | 11:17 AM
  #103
hacim105's Avatar
Ok so what are the belt sizes you have all used for this crank?
Old Jan 28, 2003 | 12:20 PM
  #104
Nathan's Avatar
Jime, so did you pay using paypal? How long did it take them to ship? Also, what did they declare the package at because I dont want to pay duties when it crosses the border.
Old Jan 28, 2003 | 02:57 PM
  #105
kink420's Avatar
udp
Just got my udp today (three buisness days after ordering). It looks great and I dont believe I paid any extra fees. I plan on redynoing my car after the install to clear up all this hype.
Old Jan 28, 2003 | 03:26 PM
  #106
Shoooter_j's Avatar
Nathan...I got my UDP yesterday. Paid by paypal, shipped via fedex and declared as a 7.99 value
Old Jan 28, 2003 | 06:51 PM
  #107
Nathan's Avatar
Re: udp
Nice! Thats what I'm waiting for. Some before/after dyno runs from various cars. If there is a reasonable difference I'll order one.
Old Jan 28, 2003 | 06:55 PM
  #108
Nathan's Avatar
Damnit! Why didnt you boyz tell me about this earlier cause then we could have shipped them together. The bling bling is in my pocket and I need something to play with
Old Jan 28, 2003 | 07:39 PM
  #109
Shoooter_j's Avatar
Doh! I think Dennis would like to ship w/ u if u're ordering...PM him!
Old Jan 28, 2003 | 08:08 PM
  #110
Nathan's Avatar
No need for PM, we talk everyday on icq Yup, we'll probably order together next month.
Old Jan 29, 2003 | 01:57 PM
  #111
AKM2k5's Avatar
Originally posted by dohccivicna1250
To person above who came. I first want to apologize greatly. That day, we discovered a theft of an AEM EMS computer, and locked the shop down with the workers inside until one of them confessed. We were in there until 3 pm until the jerkoff worker who stole the computer confessed, if you dont believe me, i will give you the workers # so you can yell at him for causing you the trouble. I greatly apologize, and will be willing to sell you a pulley for half off to make up for it.
I apologize for the inconveniece, but a 1,100 dollar AEM computer is no joke, and the matter had to be handled.
Also, Fabio NO LONGER works for us, he is the thief, and if you know who he is, tell him to cough the money up
Damn, Fabio doesnt do "i cant belive its not butter commercials," and he stole things from you? He must be desperate...
Old Jan 29, 2003 | 02:54 PM
  #112
Nathan's Avatar
Fabio sounds very familier to me for some reason. I think a guy named Fabio tried screwing me on an intake I ordered from him through the net. Maybe its the same dude.
Old Feb 6, 2003 | 08:55 AM
  #113
Grey00lustre's Avatar
dohccivicna1250, is it too late too still get the crank pulley for $80 shipped...cause i want it also...
Old Feb 12, 2003 | 06:05 PM
  #114
Jarhead96SE's Avatar
dohccivicna1250, YGM!
Alex
Old Feb 12, 2003 | 07:01 PM
  #115
Pulley Deal
discount is still on on this first batch. We have 7 pullies left, so if anyone is holding out, act quick. Our next batch go delayed by the manufacturer, so we expect it in 1.5 mths
Old Feb 12, 2003 | 09:09 PM
  #116
ardika's Avatar
Re: Pulley Deal
Eli,
I was planning to give you a call to take up on your offer for the 50% pulley price (for waiting outside your shop when you were having trouble with Fabio), but I don't have your phone number anymore.
Can I e-mail you instead?
Let me know,
Armand
Old Feb 13, 2003 | 07:16 AM
  #117
Re: Pulley Deal
Please check your e-mail. Also, you've got PayPal!
Alex
Old Feb 13, 2003 | 06:28 PM
  #118
y2kse's Avatar
RVM UDP is installed. So far, so good. Check this thread for info on proper belt sizing:
http://forums.maxima.org/showthread.php?threadid=189404
Old Feb 20, 2003 | 09:14 PM
  #119
97MaximaSE's Avatar
if 80 bucks shipped is still going on let me know i will paypal tomorrow...thanks
Old Feb 21, 2003 | 03:47 PM
  #120
RI-Max's Avatar
are these still in stock???
