You guys are asking for Yellow OPTIMA's also:
Old Oct 29, 2003 | 08:53 AM
batteriesareus's Avatar
I will run the D850U Yellow top dual post on sale for you guys today only for $141.99 delivered:
Let the groups know! --> and just
put (Maxima group special $141.99) on the comments for your order!
http://batteriesareus.com/shop/produ...products_id=34
Check it out!
www.batteriesareus.com
sales@batteriesareus.com
Old Oct 29, 2003 | 08:57 AM
DanNY's Avatar
Ad·min·is·tra·tor
possible you can do dual post red tops too for the non deep cycle people?
also..anyway you can do better than that for the yellow? the blue is going for 130ish shipped a few posts down.
Old Oct 29, 2003 | 09:37 AM
maximadave's Avatar
detailerdaveb@gmail.com
it's cheaper at Costco...
Old Oct 29, 2003 | 06:29 PM
image's Avatar
i bought my yellow top for 152 shipped. DAMNIT!
Old Oct 29, 2003 | 09:30 PM
nismaniac's Avatar
Check it out!
I've been looking at your website. Of all the models of optimas you have, which models are for the 2k2-2k3 Maxima? I am assuming no modification is neccessary to install the optimas, correct? By the way, I don't need any extra posts for audio. I have my power amp connected to the pos terminal.
Old Oct 30, 2003 | 05:46 AM
PoLo's Avatar
2-Wheelin it...
well, you could always do this and leave your main power connection alone
Old Oct 30, 2003 | 10:38 PM
nismaniac's Avatar
That's awesome, but my setup is not that sophisticated. What model do I need. And I am assuming that no modification is needed correct?
Old Oct 31, 2003 | 04:56 AM
nubiannupe's Avatar
OG Maxima.org Member
No modification needed.
Old Oct 31, 2003 | 04:59 AM
Guys;
My research indicates the BEST battery for the 2002-3 Maxima needs a reversed post battery: The R800 Red top. We have it in stock for $119.99 delivered.
----http://batteriesareus.com/shop/product_info.php?cPath=21_22&products_id=33
By the way - the car pictured above is awesum!
and We would like to know the manufacturer of the battery terminals pictured on this Yellow Top, so we can add them to the website. Please email me information direct.
Old Oct 31, 2003 | 04:58 PM
nismaniac's Avatar
Guys;
Thanks for replying. So does the reversed post battery alleviate the problem of having to modify the pos terminal to stretch long enough to connect properly? If so, then I will definately get this one. I have had a problem finding out which optima will fit properly without modification. Also does this red top offer a little more power to help with powering a 300watt amp and sub? Its not a big system, so I don't think I need the complex setup that polo has (although it looks awesome). I appreciate your response, hopefully if this battery solves the above problems, I can buy one soon.
Old Oct 31, 2003 | 05:11 PM
Yes, the R800 takes care of the crossing cables / stretching them across the battery problems. Optimas design does help with drain and reserve problems associated with larger power draws.
The Red top will help vs lead acid technology. The impressive gains with large systems is seen with the DeepCycle products. I too like Polo's setup,
and will be adding the Stinger products soon.
Thank you all for your support and interest!
Old Nov 2, 2003 | 09:57 PM
nismaniac's Avatar
I just want to make sure I understand you. Here are some pics:
Yellow top
Completly stock
Red top reversed
The problem is not the positive and negative poles on opposite sides, it is the distance that the actual pole is from the top (side closest to windshield) of the battery. Notice the pic of the stock battery and terminals (close to top) and yellow top picture (more towards middle or bottom). Are you suggesting I turn the 800R around (so the label is upside down) for it to install correctly? It looks like that should work. Is there any problem with this besides the label just being backward?
Thanks for the help.
Old Nov 3, 2003 | 05:51 AM
Hello;
I tried the forum earlier, but it was down?
The R800 has the posts reversed. With the battery sitting in front of you and
the terminals nearest you the positive post would be on the right hand side.
(yes, the posts are opposite of the D850u Yellow top)
Looking at the pictures it appears that the R800 will fit, and the label
may be backwards on this install.
Thank you for your time and interest.
Old Nov 3, 2003 | 05:10 PM
nismaniac's Avatar
Hello;
Cool. I think I will just get the 800R and turn it around. I just wanted to be sure that is what you meant. When I am able to buy it, should I just email you and let you know I am on the org to get that price? It is more on the website. Is this a one time offer, or a Maxima.org discount? Thanks for the good offers.
P.S. the .org is being really fussy right now. Anymore than 200 users at a time, and it freaks out.
Old Nov 6, 2003 | 10:03 AM
largestal's Avatar
order my yellow on Monday. I hope it arrive soon, my baby is suffering due to lack of POWER!
Starrider
Dec 18, 2015 04:43 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
Maxboy23
Sep 4, 2015 06:04 PM
trungg86
Sep 4, 2015 04:58 AM
