4th gen - gauging interest +6hp/+9tq for $100
Old Jan 25, 2004 | 07:15 PM
  #121
Maximum96's Avatar
All we need will be the TB gasket, ours is VERY thin material, that might prove some gains, and maybe half the price, since we do not need the manifold gasket
Old Jan 26, 2004 | 12:53 PM
  #122
Ceasars Chariot's Avatar
Old Maxima Legend
o man, this is disapointing news, what to do now ?
Old Jan 26, 2004 | 05:04 PM
  #123
gabex's Avatar
I don't know, but Sean said I could still get my dyno
Old Jan 26, 2004 | 05:06 PM
  #124
99Maxima5sp's Avatar
This is bullsh!t, why did those engineers have to make our motor so damn good from the factory?!?
Eric
Old Jan 26, 2004 | 05:33 PM
  #125
brianw's Avatar
Well, good to know we don't need it and that it probably wouldn't be an improvement anyway.
Good to know Nissan has done a few things right on our cars. (if we have to put up with a minivan rear suspension, the drivetrain had better be damned good! )
Old Jan 28, 2004 | 02:25 PM
  #126
Old Maxima Legend
hey be sure to let me know the results. maybe they could make a few custom jobs. im going to have my stock one replaced soon. it must be getting old has a few tiny leaks coming through.
Old Jan 29, 2004 | 01:26 PM
  #127
MAXimumHP's Avatar
Eric
No kidding, don't they know we want to spend money on this stuff.
Old Jan 29, 2004 | 05:35 PM
  #128
gabex's Avatar
I dont know if many of you understand the outcome of my visit with Sean Morgan (of OE).
Sean Morgan did not find any evidence that says we would get sufficient gains (6hp/9lbtq like the subject says). We already have thick gaskets. The hp gain might only be like 1hp for the VQ. That in his mind is not worth creating a product for, whether or not you guys would still buy it. He has plenty of cars that do well with these and have great gains (those cars with thin: paper, metal, or some other material for a gasket). It is not worth it for him or us to have these manufactured.
Old Jan 30, 2004 | 06:10 AM
  #129
BEJAY1's Avatar
Conecarver
Sorry to hear the disappointing news. It was worth looking into though I think.
Whenever non Nissan owners look at my stock gasket they always think it's already been upgraded looking at the thickness of the thing.
Interesting about the 180deg lower man temp. That's "exactly" what my coolant temp is no matter the outside temp 50deg or 0deg. Haven't gotten a summer reading yet though.
I wonder what gains (if any) the TB gasket might produce either through heat isolation or the longer distance. Maybe OE could cut us one or two to try out. Those should be a cinch to measure and just cut. PowerAid already makes spacers for late model Pathfinders.
If somebody with a VE or VG wants to run those engines past Sean then go right ahead. I don't know how those OEM gaskets are sized to begin with. He mentioned he already had a local VG available to play with (maybe an employees).
Thanks again Gabe for your time and effort. Sorry to get everyone's hopes up.
Next idea?
Old Jan 30, 2004 | 06:19 AM
  #130
thisasian's Avatar
Well, at least we can rest easy knowing that we get to drive a fine piece of well engineered Japanese machinery.
Old Jan 30, 2004 | 08:16 AM
  #131
Maximum96's Avatar
they dont even want to try 2 make a TB Gasket, our gasket is a POS for the TB
Old Jan 30, 2004 | 09:56 PM
  #132
Old Maxima Legend
bejay1 -gabex, what about this TB gasket ? what would be the advantages of getting them to work on this ? if there is something here, lets get this started ..lol but seriously!
Old Jan 31, 2004 | 04:21 AM
  #133
MaxedOutR34's Avatar
What about them making a Throttle Body Spacer and Gasket for us?
Old Jan 31, 2004 | 09:34 AM
  #134
Maximum96's Avatar
how many mm is our TB, i am thinking of setting mine up somehow.....is it 66mm or 68mm or what i forgot??
Old Feb 2, 2004 | 11:46 AM
  #135
gabex's Avatar
Maxima lovers:
After seeing the amount of interest this topic drew on the Maxima.org board, Outlaw Engineering was definitely excited about working with this fine piece of automotive engineering. We have had a great expreience working with the SR20DE folks and felt that designing a kit for the VQ motor was a logical next step.
However, after examining the intake manifold setup on Gabe's '95 VQ motor, we came to the conclusion that a ThermoBlok kit will be of no use to the Maxima crowd. As stated earlier in the thread, it appears that Nissan uses a 3/8" thick gasket (my guess is EPDM or polyacrylic rubber, not silicon) that already effectively thermally separates the upper intake plenum from the short lower runners. We measured a healthy 50-60 degree F temp difference from one side of the gasket to the other which is about par for other applications using ThermoBlok kits.
It also appears that a throttle body spacer would not be beneficial either as Gabe's was very cool and did not appear to have coolant running through it. I'll admit however, that I didn't look closely at the throttle body after we determined the intake spacers wouldn't be useful. Can anyone verify if the throttle body has coolant flow???.
As for the AirMax and Tornado products, please don't waste your hard earned cash. I won't go into the details at length in this post, but the only performance gain will be due to the weight reduction of your wallet. These spacer DO NOT effectively swirl the intake air. Even if they did, the swirl would decay long before it ever approached the intake valve. Additionally, swirl always induces a flow restriction...always...period.
Also, spacers between lower manifold and cylinder are not possible due to the fact that that the addition of spacers to the angle of the intake ports in the V configuration would create a geometry mismatch between the port in the cylinder head and intake runners.
As much as Outlaw would love to sell thousands of ThermoBlok kits to Maxima owners, we cannot do so in good conscience. Others may come along that seek to separate you from your money, but we don't do business that way.
Kudos to Gabe for being willing to brave the cold and snow to bring his car over and to all the others that talked to us about this project. If other details come to the surface that would make this or a throttle body spacer an effective mod, we would be happy to work with you guys.
Sorry about using your user ID Gabe, there's obviously a cookie from when you logged on during your visit!
Sean Morgan
Outlaw Engineering
Old Feb 2, 2004 | 02:13 PM
  #136
Jason R's Avatar
aka UNCDooD
yes it does. there are a lot of guys that do the 'TB coolant bypass mod'.
Old Feb 2, 2004 | 03:32 PM
  #137
Would a TB spacer help at all?
MattWithTheMaxima
Jun 30, 2017 01:06 PM
vingodine
45
May 21, 2016 12:46 PM
Finkle
Sep 27, 2015 09:53 PM
240tomax
Sep 4, 2015 04:33 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
