HID Plug and Play Kits $160 SHIPPED Head Lights, Fog Lights!
Old Apr 29, 2008 | 07:19 PM
  #1161
cooldude585's Avatar
Hi,
I have a 95 maxima with stock lighting. What all parts would I need to upgrade to the HID's.
Old Apr 30, 2008 | 07:36 AM
  #1162
operatic's Avatar
Former Sponsor
Originally Posted by jigmoney
I have a 1998 infiniti i30t with cefiro headlights Hid ready
I havent done naything yet. What do you suggest me to do?!
Also I was told that the bi xenon requires me to do additional work on my headlights. I don't want to proceed this way so whats the best thing to do?!
For the ceferio, if you wanted to do both your high and low beam, we can do it so it'll use the H4 bulb and the 9004 connector that plugs into your OEM connector so it'll be plug and play for ya.
Originally Posted by sil SE
PM'ed about 9004 bulbs thank you
Hit you back partner!
Originally Posted by cooldude585
Hi,
For your 1995 Nissan Maxima you'll need a 9004 for your high / low beam and an H3 for your fog lights.
Old Apr 30, 2008 | 09:11 AM
  #1163
dineth00i30's Avatar
hey operatic, i called you today also i wanted to know that if you guys have 9003 and 899 bulbs. i want 8000k for 9003 and custom yellow for 899 bulb. this is for my other car which is a 03 mitsu galant. let me know.
Old Apr 30, 2008 | 10:13 PM
  #1164
stephen90's Avatar
hey i have a 03 maxima se stock lighting
very interested in your hid kits but i am not an expert in this field>.>
mind telling me what i need if i wanted the 6000k
and around how much would everything cost.
also whats the difference between the bi and the single?? and would i need a "retro fit projector"; whatever the hell that is, becuase i've been reading a lot of threads
about the light scattering everywhere which causes police attention, failing inspection blah blah blah... I am not sure what that is about but would the hid lights in my 03 housing be scattered everywhere or just the older generations have that problem. thank you!
Old May 1, 2008 | 04:43 AM
  #1165
operatic's Avatar
Former Sponsor
I'm sorry about not getting back to you yesterday, kind of a hectic day. I apologize about that. We do have the 9003 in 8000k in stock. The 899 in yellow is a special order item, we do not have any in stock. Those are an added $20 with a 9-13 business day turn around time. I also sent you a pm!
Your 2003 Nissan Maxima SE comes with D2R HIDs from the factory. So if you wanted to change the low beam bulbs to 6000k, it would be $60 shipped for a pair. Basically all you would be doing is changing the bulb nothing more as your car already has HIDs.
For your, you do not need to worry about any of that since your car came with factory HIDs.
____________________________
We also offer LEDs now, slowly but surely we'll get it all onto the website, but if you want something let us know, more than likely we have it!
LEDs for the license plate
Before
During
After
Old May 1, 2008 | 08:03 AM
  #1166
hey pat, don't worry about not getting calling me back but, you sent me the wrong pm. I'm the that want 9003 bulb not the maxima d2r bulb. So anyway since I didnt see the 9003 or 899 bulb how do i order? Should i just call you? If those led's are brighter than lexus or as bright as them I'm in for a set. How much?
Old May 1, 2008 | 04:44 PM
  #1167
stephen90's Avatar
sweet thanks!
just one more question about my fog lights.
if i wanted hids 6k in those too but maybe blue or yellow, how much would that be and would i need to do anything special to replace my original fog lights?
in terms of payment what methods are you willing to accept?
thank you so much once again.
Old May 2, 2008 | 04:32 AM
  #1168
operatic's Avatar
Former Sponsor
Give Hanh a call at 832-428-2431 he'll take care of you right away. The 9003s are also H4. And the 899's are also 880's. As for the LEDs, they are just as bright as the lexus ones. And they are $10 for a pair when ordered with HIDs.
sweet thanks!
Na, 6000k is a very nice crystal blue.
And as long as you pick the kit needed for your car you'll need nothing special to install our HID kit.
Old May 2, 2008 | 09:27 AM
  #1169
stephen90's Avatar
thank you i will be using your website to place my order!
just to make sure i need the D2R hid bulbs am i corect?
Old May 2, 2008 | 04:10 PM
  #1170
operatic's Avatar
Former Sponsor
Yup, since your 2003 Maxima comes with factory HIDs, you use the D2R bulbs to replace them.
http://shop.3bspecialties.com/produc...0&productId=45
Old May 2, 2008 | 04:42 PM
  #1171
Anachronism's Avatar
one light yellower than the other
Originally Posted by operatic
Usually this is caused by one lens being dirtier than the other. You know how over time they get a little yellow film on them (really noticeable on older cars.) This could be the cause of it. If not, you can always swap the bulbs around see if one of the bulbs is preternaturally failing. If it is, we got you covered under warranty partner
Cleaning them did the trick, the inside was pretty dirty. They still are not quite as white as the stock HIDs but the fog light lenses are pitted pretty badly so that is probably the reason.
Old May 2, 2008 | 09:16 PM
  #1172
stephen90's Avatar
thanks again bro! now i cant wait to get them =0
Old May 3, 2008 | 08:05 PM
  #1173
operatic's Avatar
Former Sponsor
You'll be seeing them before you know it!
Old May 4, 2008 | 06:37 AM
  #1174
operatic's Avatar
Former Sponsor
PMd everyone back
Old May 4, 2008 | 07:19 PM
  #1175
hey I have bit of a problem I ran into while my mechanic was installing the kit into my fog lights. Ok so he put all the wires and the ballast and the relay harness. Now, from the xenon bulb there is a wire that has these little metal pieces that go inside the fog light assembly and there is a another kinds big wire coming from the bulb that has a plastic plug( or what ever u call it). Where does that go to? If my memory is right it has a blue and black wires so does that plug into the harness or the ballast? I wish I have pics but I don't . If you really need them I will try to get some pics. Thanks I really want to get this on bcus as of now I have the whole foglight assembly off the car.
Old May 5, 2008 | 04:05 PM
  #1176
vaudeville's Avatar
I'm praying you didn't ship mine yet! if yes I'm out of luck...oh well.
Old May 5, 2008 | 05:23 PM
  #1177
operatic's Avatar
Former Sponsor
Sent you a PM
Nope, they have not gone out yet
Old May 6, 2008 | 01:30 PM
  #1178
illlojik's Avatar
I C U
I'm looking for a bi-xenon setup for a 2k Maxima stock housing. 6000K. Which setup would I need? (As far as any additional adaptors, pieces,etc go)
Is the price still $270 shipped? (11553 zip) thanks
Old May 6, 2008 | 06:47 PM
  #1179
operatic's Avatar
Former Sponsor
A bi-xenon set up would be $270 shipped, you would need nothing extra either, our kit comes with everything you need to get it up and running.
Also, if you want, a lot of people are very satisfied with the single xenon kit which for your car comes with a xenon low beam and a halogen high beam. Granted the halogen high beam is more for just flashing than anything, but a lot of people are satisfied with that. They are $130 shipped.
Old May 7, 2008 | 06:43 PM
  #1180
operatic's Avatar
Former Sponsor
up for some HIDs!
Old May 7, 2008 | 06:59 PM
  #1181
Puppetmaster's Avatar
Thanks for all the help, guys! I've had a great experience dealing with you. I'm all set now.
For others who want to leave comments, I started a thread here:
http://forums.maxima.org/showthread.php?t=561439
Old May 8, 2008 | 11:46 AM
  #1182
illlojik's Avatar
I C U
payment sent
Old May 8, 2008 | 07:31 PM
  #1183
operatic's Avatar
Former Sponsor
Glad it was pleasurable! Hopefully more people will post up in the thread you made about their experience with us
Originally Posted by illlojik
payment sent
You'll be seein' your kit before you know it!
Old May 8, 2008 | 08:38 PM
  #1184
Hey, as I promised I'm ordering another HID kit tommarow or day after. Anyway I want the LED's for the license plate for my infiniti. So how do I get it? Is it up on the website yet? Or I have to call?
Old May 9, 2008 | 07:52 AM
  #1185
regalgs on dubz's Avatar
Pm sent
Old May 9, 2008 | 04:00 PM
  #1186
operatic's Avatar
Former Sponsor
We have them on the website, but it charges you for shipping, just give Hanh a call at 832-428-2431 and he'll do your order over the phone.
Originally Posted by regalgs on dubz
Pm sent
Never got your PM partner
Old May 9, 2008 | 04:12 PM
  #1187
illlojik's Avatar
I C U
Great transaction. Got it early today. I'll throw them in this weekend weather permitting. thanks
Old May 10, 2008 | 12:36 AM
  #1188
2LEET4U's Avatar
Hello......
i have a 05 maxima with stock HID lights. All i want to do is upgrade my stock HID xenon bulbs to New 8000K HID xenon bulbs.
So i dont need the kit nor do I want to buy new ballast.
All I want to buy are the correct bulbs for the upgrade.
I was told to get a pair of 8000K, D2S HID bulbs at 35W.
Can you please confirm and do you have those bulbs in stock?
Thanks,
Rick
Old May 10, 2008 | 03:17 PM
  #1189
illlojik's Avatar
I C U
Having some trouble wiring up the kit. Do you have any instructions on what goes where for a 2k max?
The only thing that worked were the halogen high beams, but the xenons are not firing up.
edit: checked out the instructions on the website... few questions though with illustrations:
I understand now that both #1 and #2 in the pic goes to each ballast right?
#3 is supposed to go to the stock harness?
And what am I supposed to do with these wires, A&B?
Also, do I have to connect these somewhere, or are they just extra connections?
Thank you. Any help would be greatly appreciated.
Old May 11, 2008 | 06:45 AM
  #1190
operatic's Avatar
Former Sponsor
Originally Posted by 2LEET4U
Hello......
Thanks,
Rick
You would just need some new bulbs which are $60 shipped for a pair. Also you do need D2S bulbs. As for 8000k, we won't have anymore in stock until mid week, we are out of stock. We do have 10,000k in D2S in stock though, but it is only 1 pair so it will probably sell out by the time you read this
2nd Picture.) Wires A and B in the second picture are for cars with aftermarket projector headlamps, so you do not need them, just tape them up and tuck them off to the side.
3rd Picture.) 1 and 2 are if you wish to forgo the wiring harness and just plug it in directly to your OEM connector. Plug 1 would go to your OEM connector and plug 2 would go to the ballast. We put that there as an option as some people just don't want to run the wiring harness.
Old May 11, 2008 | 07:47 AM
  #1191
illlojik's Avatar
I C U
Ahh, thank you. I'll give it a try.
Old May 12, 2008 | 10:43 AM
  #1192
illlojik's Avatar
I C U
Bump for great transaction, great customer service and a great product. Will definately be doing more business in the near future.
Old May 12, 2008 | 11:50 AM
  #1193
ajcool2's Avatar
pm sent..
Old May 12, 2008 | 05:49 PM
  #1194
operatic's Avatar
Former Sponsor
Thanks partner!
Originally Posted by ajcool2
pm sent..
Hit you back
Old May 13, 2008 | 08:47 AM
  #1195
prince_starbai's Avatar
Operatic: do you have an installation or wiring diagram of how to install the H3 fog light kit into my 1998 Nissan Maxima?
Thanks!
Old May 13, 2008 | 07:13 PM
  #1196
operatic's Avatar
Former Sponsor
Thanks!
Sent you a PM!
Old May 13, 2008 | 08:57 PM
  #1197
ptviperz's Avatar
PM sent
Old May 14, 2008 | 07:10 AM
  #1198
operatic's Avatar
Former Sponsor
Hit you back
Old May 14, 2008 | 07:36 AM
  #1199
ptviperz's Avatar
Hit you back
Didn't get anything?
Old May 14, 2008 | 08:22 PM
  #1200
sup. im back! i just got my 2 8k kits and the license plate LED'S that i baught from hanh on the phone and i thaught i should just let u kno.anyway they look awsome and guess what all my friends want them guess where they gon order them from? cough: im looking for white LED'S for city/parking light : cough jk
