2000-2001 Navigation...
Old Dec 29, 2002 | 01:45 PM
Chris-alty
Hi guys,
I'm just curious if anyone has added the pop up navigation to their i30's. My parents have a '01 i30t, fully loaded except for navi. I may be purchasing it after the lease it up and i would love to have the navi in there.
Anyway, any info, comments, suggestions etc. are welcomed!
Old Dec 30, 2002 | 12:51 AM
anthunny's Avatar
Re: 2000-2001 Navigation...
Thats the problem, maxima and I30s OWNED accord soo badly and TLs previously. But now ur lackin the navigation, wtf?
Fine I wont compare TL to the max, since its soo much more, but even a accord, which used to be inferior, now has navi with 5spd auto, maxi doesnt have either?? hopefully it changes in 2004
Old Jan 4, 2003 | 01:34 PM
00MAXIST's Avatar
Re: Re: 2000-2001 Navigation...
WTF??? Do some research, you can get navigation in 03 Maxima's and in I30's from this current generation. However it is an option, find a car in this price range that is including Navigation for free.
Old Jan 5, 2003 | 04:38 PM
BBaker025's Avatar
you can get an aftermarket nav. system from Alpine or Pioneer much cheaper than the OEM system.
Old Jan 5, 2003 | 11:37 PM
anthunny's Avatar
HONDA.CA new fully loaded accord with nav, leather and everythin, ex v6 is only 33500 canadian. A top of the line max with everythin and not counting the nav is like wha 36 37k, GLE model? no 5spd auto as well.
Old Jan 5, 2003 | 11:47 PM
MetaOrbit's Avatar
Got Projectors?
My I35 didn't come with NAV and I was in the same situation as you. I also looked at the Pioneer systems (nice!) but don't quite have the funds on hand for that kind of operation.
Instead I got a Pharos GPS system (GPS receiver antenna, nationwide map software) for my Jornada Pocket PC (Also upgraded to a new Jornada at the same time). It has voice prompts, text directions, and auto-rerouting. I even got a nifty mount for it on the dash
You may want to look into something like that if NAV is something you want. It's affordable, has the features, and what's cooler than having a pocket pc to play around with when you're outside of the car
Old Jan 19, 2003 | 09:06 PM
Chris-alty
Yeah, good ideas, but i would love to have the pop up screen. Not just for navi, but for dvd's (company in brooklyn, NY does oem navi - mulitmedia setups). I have to look into this some more and see.
Maybe, someone with the pop up navi could post soem pics of it? not the lcd itself, but the inside, maybe some of the mechanics? SOmething to help. Infiniti dealerships don't like me looking at that kind of stuff, lol.
Old Jan 19, 2003 | 11:06 PM
MetaOrbit's Avatar
Got Projectors?
I can get ya pics of the Pop-up nav for the I35. My dad's I35 has it. So maybe I can get some in a few.
John
P.S. I went searching through my webspace and found some images from my car and my dad's car. Just so happens I have a video file showing his NAV setup - so it might be helpful:
http://mywebpages.comcast.net/metaor...5/videonav.mpg
Old Feb 3, 2003 | 09:55 PM
BEEI30's Avatar
John
I am also looking to put that in to here.
Old Mar 4, 2003 | 05:28 PM
MetaOrbit's Avatar
Got Projectors?
How did you remove the air vents/dash/etc? Particularly the air vents. I'm going to need to remove my HU sometime soon and was wondering how to go about getting to the mounting screws.
Thanks!
John
Old Mar 5, 2003 | 08:21 AM
BEEI30's Avatar
Use a flathead screwdriver and carefully pop the air vents out from the bottom.
Old Mar 7, 2003 | 05:46 PM
][ 35's Avatar
any more detail? b/c i tried and it don't work.. i have popped it out little all around but still won't come out.....
ic that ur car is I30.... do u know if it's different for I35?
Old Mar 7, 2003 | 05:59 PM
MetaOrbit's Avatar
Got Projectors?
I just did it this afternoon. It's the same. I found (by MaineI30's advice) that it was easier to put the screwdriver in a cloth, then work at the vent assembly from the sides. You'll have to be a little rough with it once you start getting it worked out, and then it will pop out (maybe with a loud bang, freaking you out thinking you broke something, but you really didn't).
Some advice - eject all your CDs before removing the HU, because inevitably, they will all eject as your hands are working all over the dash. Mine spit them all out at once, hehe.
Old Mar 7, 2003 | 06:06 PM
BEEI30's Avatar
It should be the same...
damn you guys with the indash cd changer.
Old Mar 7, 2003 | 10:04 PM
][ 35's Avatar
thanks....
i finally figured it out... like metaorbit said...
i had put yank on it and it just came out with a bang hahaha..
i also thought i broke something but it was all good ....
and to remove the HU.... do u just unscrew the top 2 screw?
or do u have to unscrew somewhere else also? if so...
how do i get the bottom part out...
thanks again....
Old Mar 7, 2003 | 10:39 PM
BEEI30's Avatar
thanks....
thanks again....
same thing you did to the air vents...pop the surrounding wood trim around the shifter. dont forget to shift to neutral to remove the wood trim. there should be two screws behind where the bottom tray was. now you are able to remove the head unit.
Old Mar 8, 2003 | 10:13 AM
][ 35's Avatar
sweet.. got to work on that this weekend....thanks
Y2KevSE
72
Aug 4, 2008 08:21 PM
GeraldSnM
Aug 23, 2002 10:46 PM
Craig Mack
Mar 10, 2002 09:20 PM
thezcarguy
Aug 11, 2001 03:15 PM
