How do you get to foglights???
Old Jan 16, 2003 | 01:36 PM
BBaker025's Avatar
I was going to rewire my foglights today, and I couldnt figure out how to get to them. Do I have to remove the whole bumper to get to them? Or is there a panel or something I can remove to access them.
Old Jan 16, 2003 | 03:52 PM
I30tMikeD's Avatar
I just had to change one of the bulbs the other day. You do not have to remove the bumper!!
It requries removing part of the undercarriage plastic. The part farthest to each side. The bulbs them selves are a pain in the *** to take out and put back in. They have wire pin type fasteners. It's kinda hard to explain.
I believe the instructions I read were in the owners manual.
Old Jan 16, 2003 | 03:59 PM
XXXL Cracker's Avatar
Deleted
Old Jan 16, 2003 | 04:12 PM
I30tMikeD's Avatar
Originally posted by dlicari
Deleted
Old Jan 16, 2003 | 04:14 PM
BBaker025's Avatar
Thanks alot Mike!
Old Jan 16, 2003 | 07:06 PM
Asian_N02's Avatar
all you need is a ratchet with an 8mm head i think. you unscrew the clearance light first, then you can unscrew the foglight. It took me a little bit to figure out, but it's extremely easy. What exactly are you going to do anyways???
Old Jan 16, 2003 | 07:41 PM
I30tMikeD's Avatar
Brian,
You just need to get to the wire harness behind the light right. Not take out the assembly? Because what I said will just get you to the wire harness and bulb.
Old Jan 17, 2003 | 12:11 AM
JSpecMax's Avatar
While your in there...
Want brighter fogs?? Remove the metal shielding piece (located in front of the bulb, looks like a hat or umbrella) By using needle nose pliers and bending/breaking the part out of the lense. It takes some time and cursing, but it is well worth it. Good luck!
-Steve
Old Jan 20, 2003 | 12:25 PM
Asian_N02's Avatar
i took my clearance light off today, but then I had a hard time putting it back on...the metal piece where you bolt the clearance light into was not lined up properly...for now I just taped it on. Does that mean my car has been in a minor fender bender? How do I get it lined up correctly...any help would be appreciated...i spent about an hour cursing and trying to bend that metal piece to line it up...as of now...it's taped on...thanks ahead of time...
Old Jan 20, 2003 | 02:54 PM
I30tMikeD's Avatar
Which one are you talking about?
Old Jan 20, 2003 | 04:29 PM
Asian_N02's Avatar
the clearance light...it's the one right beside the foglight.
Old Jan 20, 2003 | 04:35 PM
Asian_N02's Avatar
Old Dec 12, 2003 | 02:11 PM
infiniusaa's Avatar
Does this work with the I30t model, because I am not seeing anything that will give me access to the fog lamps
Old Dec 12, 2003 | 10:49 PM
I30tMikeD's Avatar
Yes, do what I said in the above post.
Old Dec 13, 2003 | 08:20 AM
Pats5spdi30T's Avatar
The most difficult time I had was getting the fog light seated properly back in proper place. It is really an awkward position to try properly seat the harness and fit the clamp over the bulb. I jacked up the car about 8 inches and could still barely get to it.
Heat0212
Oct 24, 2020 12:36 AM
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
Hdnseek
Sep 9, 2015 05:55 AM
fc95se
Nov 15, 2000 05:14 AM
