Max tire size on a stock 15" wheel ?
Old Jan 26, 2003 | 04:39 PM
humberto_i30's Avatar
I'm planning to replace my worn tires in my '96 I30 but I want to replace the current 205/65-15 with 215 or 225/65-15 if this is possible, any one know what's the max wide size that my car can accept with no problems ? I appreciate your answers !
Old Jan 26, 2003 | 05:46 PM
JJ-2001MAX's Avatar
Tire Size
Try this: http://www.miata.net/garage/tirecalc.html
JJ
Old Jan 26, 2003 | 09:25 PM
I30tMikeD's Avatar
Re: Max tire size on a stock 15" wheel ?
Well you have 6" wide wheels. 215's are probably possible but I bet they won't be within spec, your tire will buldge out over the rim a little. 225's no way.
Old Jan 27, 2003 | 05:33 AM
max5spd's Avatar
Says.."No mo Maximas for me!"
From 205-65-15, you would want to go Plus 0 which is 215-60-15 and that's the stock size for the I30t. You want to stay within the same diameter or your speedo will be way off. I think that 215's are the max you can go.
The Tire Calc on miata.net is a very good one and I use it all the time. Definitely, 225's won't fit. You'll need a 6.5"-7" wheel for that.
dank4us
34
Jun 10, 2024 03:45 AM
homeyclaus
Sep 3, 2015 06:15 PM
sonic7
Aug 20, 2015 12:23 PM
maximaham
Aug 20, 2015 10:23 AM
twotonezed
Aug 16, 2015 11:41 AM
