Hello all..
Old Jan 27, 2003 | 09:39 AM
kamakaziep's Avatar
Hello all..
I was here years ago with my 1991 Maxima, and unfortunatley my 95 Audi A6 died. So i left audiworld.com to find my original home here at maxima.org I have to move a heavy load of stereo equipment and find out how to mount my 2nd alternator from the audi to the infiniti. But i have 1 quick question. Will the supercharger kit from the Maxima fit the I30. I know they are just about the same but you cane be too sure. thanks!
Old Jan 27, 2003 | 09:59 AM
BlueC's Avatar
wat
Re: Hello all..
Aslong as its the same Generation, then yes...
Old Jan 27, 2003 | 12:50 PM
MetaOrbit's Avatar
Got Projectors?
Welcome back! I knew that your name, Jack Palazzo, sounded familiar...I finally figured it out!
Apparently I read one of your testimonials on LEDtronics LED "bulbs" before I bought them..
http://www.ledtronics.com/datasheets...ls/testim1.htm
Small world hehe.. As for your question, I imagine the Stillen S/C should work with relatively no problem on your car.
Old Jan 27, 2003 | 01:35 PM
kamakaziep's Avatar
thats great! I have a set of their compeditors as well they have a single led bulb that is super bright yet its only 1 led. its by ledcorp.com
Small world!
Old Jan 27, 2003 | 01:36 PM
kamakaziep's Avatar
Small world
Small world!
Old Jan 27, 2003 | 01:44 PM
MetaOrbit's Avatar
Got Projectors?
How does that bulb from ledcorp.com compare? It seems to me that only 1 LED wouldn't light up the sides of the reflector as well as the ones made by LEDtronics, what's your take on it?
Old Jan 27, 2003 | 02:31 PM
fst96se's Avatar
Hey all, I am interested to know if there is an LED bulb (or any type for that matter) that is a dual filament, that when lit in the "not so bright" mode is white, but when on it's brighter cyle is red or orange or yellow.
My i30 now has clear turnsignal lamps (thanks mike), but the bulbs are orange. It is a dual filament bulb, and always stays lit when running lights or headlights are on. Annoying for the orange to fill the clear corners for sure. I would like it to run white, and flash orange, anyone ever heard of any type of bulb that would do this??
Old Jan 27, 2003 | 02:37 PM
MetaOrbit's Avatar
Got Projectors?
Hmm...none to my knowledge...probably has to do with the varying voltages between the different color LEDs makes it more difficult (read: more costly/time consuming) to make it work with 12v.
Old Jan 27, 2003 | 02:39 PM
fst96se's Avatar
Old Jan 27, 2003 | 05:16 PM
kamakaziep's Avatar
Ledtronics led
The single ledtronics bulb uses a luxeon star led. it is viewable at full intensity t 90 degrees and 70% at 180 degrees. This led will light up the whole reflector. However i also can get you guys the white led to flash whatever color you want. The new RGB leds can make any color. Ill get you more info as soon as i get it figured out..
Old Jan 27, 2003 | 05:22 PM
MetaOrbit's Avatar
Got Projectors?
Re: Ledtronics led
Awesome! I had no idea there were manufacturers (other than OEM's) using the Luxeon stars.
Too cool.
You don't know if they'll be coming out with a 194 application do you?
Old Jan 27, 2003 | 07:12 PM
I30tMikeD's Avatar
Shwan, I had some cheapo hyperwhite bulbs in mine. They do give a blue reflection when not in use, but are white when turned on. But I imagine you would like to stay leagal with your lighting, being your the law and all.
ColdCananda
Sep 20, 2015 10:45 PM
Tuna
Apr 25, 2003 08:36 PM
massvmax2003
Apr 18, 2003 07:55 AM
massvmax2003
Jan 21, 2003 11:09 PM
