Getting 17" wheels, what diamiter tire to use?
Old Feb 25, 2003 | 10:17 AM
infinitiman96's Avatar
Hey everyone, I have a 1998 I30 standard model and I want to get some 17' ADR Akunin wheels. They are 17 by 7 with an offset of 38. Can I use 215 45 ZR17 tires to fit this wheel combination? Also since the offset is 38 and not the stock 40, will this affect the cars ride?
Old Feb 25, 2003 | 05:25 PM
max5spd's Avatar
Says.."No mo Maximas for me!"
Re: Getting 17" wheels, what diamiter tire to use?
Your stock size is 205-65-15, right? If so, I would go with 225-50-17. If the wheel was 17x8, then 235-45-17 would be a better fit.
Check here
Old Feb 25, 2003 | 07:13 PM
My stock size is 205 65 15, I read in the max faq section of this website that I could use 215 45 17's on 17 by 7 inch wheels. Is this the case though, because I already have these tires which I bought off a friend but dont have the wheels yet.
Old Feb 25, 2003 | 07:46 PM
max5spd's Avatar
I think it's 225-45-17 that would work, not 215.
Old Feb 25, 2003 | 08:30 PM
I30tMikeD's Avatar
The 38 offset will be fine. It will actually be better because the wheel won't be inset so much. I went from a 45mm offset to 40 and I wish I would have gone to 38mm offset.
Are you sure your stock offset is 40 not 45?
Old Feb 26, 2003 | 06:41 AM
SLC I30t's Avatar
you really should go with a 225/45.
I would go on to say that depending on the offset, a 235 will cup really bad because of our inability to adjust camber. a 215-45 will work on your car but your speedometer will be off about 3mph.
alahjahwan09
18
Sep 21, 2015 09:12 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
240tomax
Sep 13, 2015 03:28 PM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
