Eibachs = Rough Ride
Hey all, I recently put in a set of eibach pro kit springs for my 01 i30. I drove home this weekend to NYC, and i gotta say the ride quality now BLOWS. Im gonna switch back to stock, but before i do i wanna be sure that i am not just doin somethin wrong... Im runnin 35psi in my tires, and my wheels are stock 16". Its too bad, cause the ride is great on the highway, but pathetic in the streets. An infiniti is just not supposed to bounce along like some honda civic with cut springs. I think im gonna quit modding and just wait for the 350z like I should have in the 1st place...
Sorry, i gotta vent...
Re: Eibachs = Rough Ride
no need to wait...its already available..
Yes, my car rides a little rougher, but the cornering is 10X better.
You sound a lot different then when you first installed the springs, why did things change???
You have too much pressure in your tires man, you should have no more then 32 psi in all of them as your cold pressure. I have a stock 98 with factory wheels on it and the manual recomends 29psi. I would bet if you lowered the pressure a bit, you would change your mind about the ride.
Did someone say that the ride changed after driving for a while on the new springs, or was bouncy and junk right off? Eibach springs on stock struts will probably wreek havoc on your struts, especialy if the infiniti struts are tuned less agressively than the maxima struts. I had eibachs on my 96 Maxima SE, and it was fine. I had progress springs on Toks on my i30, and even with a coil cut they felt great.
BTW Mike, everyweek I try to pick up another VQ at auction and I can't do it!
Originally posted by I30tMikeD
Did you sell the I30 with the progress on it or did you take them off? If you still have them I'll take them off your hands, I want to go a bit lower.
litch
123
01-04-2024 07:01 PM
MaxLvr21
10-17-2015 12:11 PM
