problem installing CAI
Old Jun 8, 2003 | 06:25 PM
infinitiman96's Avatar
I installed my CAI today but I had a small problem, I didnt remove the factory ram air or tubes because of a sensor on the bottom of the ram air I was unsure of. Is that sensor the Ambient temp sensor? I want to remove the stock tubing but am unsure of what to do with that sensor, any ideas?
Old Jun 8, 2003 | 08:42 PM
BBaker025's Avatar
Yep, thats the air temp sensor. It should have a rubber gromit around it which you should just be able to pull the sensor out. Your CAI should have a hole for the sensor. What kind of CAI did u get?
Old Jun 9, 2003 | 03:57 AM
Asian_N02's Avatar
Yup. The Place Racing CAI has a hole for it. It's kind of hard to get in, but you just got to force it in there.
Old Jun 9, 2003 | 08:53 PM
I got a BOMZ CAI off ebay and i've already tried to see if it would fit the hole in the pipe but it wont reach
Old Jun 9, 2003 | 08:56 PM
since the sensor wont reach the CAI, does this mean I have to keep the stock ram air on or can I simply zip tie the sensor somewhere else?
Old Jun 9, 2003 | 11:48 PM
ThurgoodJenkins's Avatar
It needs to be somewhere where it gets a steady flow of air. I found this out the hard way at the track when I removed it w/ my filter and the car died at about the 60' mark.
Old Jun 10, 2003 | 09:59 AM
mutatedfrog's Avatar
I have a newbie question here: i know there are a few different types of cold air intakes out there, but what brand do you guys suggest for a 2k2 I35?
Old Jun 10, 2003 | 02:36 PM
What if I splice the wire to the sensor and simply make it long enough to reach the CAI, would the increase/decrease in resistance effect that sensor reading?
Old Jun 10, 2003 | 04:39 PM
That would work if you knew what you were doing. Lengthening it just a little won't increase resistance enough to cause anything negative.
Lakersallday24
Nov 7, 2024 07:31 PM
Cotozic
Jun 28, 2017 08:01 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
lowpost99
22
Sep 2, 2015 04:38 PM
kirkhilles
Aug 8, 2015 10:53 AM
