How do i program my 96 I30 remote?
Old Jul 29, 2003 | 04:01 PM
thebigmin's Avatar
i just bought my I30 like a week ago....and the guy gave me the remote, but said that the battery is dead....
i put a new battery in and it doesn't work(probably because all the memory was lost...after a few years of not being charged)
How do i reprogram the remote...thanks
Old Jul 29, 2003 | 04:05 PM
thebigmin's Avatar
nm i found how.... im gonna go try
. Close all doors and lock all doors
2. Insert and remove the key from the ignition key cylinder more than six times within 10 seconds.
(The hazard warning lamp will then flash.)
Note:
Key should be withdrawn from ignition key cylinder completely each time.
3. Insert key on ignition key cylinder and turn ignition key switch to "AAC" position
At this time, the new ID code is entered and original (previous) ID codes are erase.
4. Push any button on the new remote controller once. (The hazard warning lamp will then flash)
If there is only one remote controller skip step 5.
5. Additional ID code entry
Release the door lock, then lock again with door lock/unlock switch
(In power window main switch)
6. Remove key from ignition
7. Unlock driver side door, open driver side door and then close the door. (END)
RIGHT?!!!
Old Jul 29, 2003 | 04:24 PM
thebigmin's Avatar
worked
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
uttadms31
Sep 30, 2015 05:24 AM
jerrod99_se-l
Sep 25, 2015 03:02 AM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
