newbie question - cylinder 4 misfiring
Old Dec 17, 2003 | 04:35 PM
jinfiniti's Avatar
This is just a repair question. I need to figure out which cylinder is #4. I have a stock 99 i30 Limited 3.0 6cyl. Reason being is that I'm getting readings that the cylinder is misfiring. I was getting various readings so i changed the spark plugs (time for it anyway). Now that I'm certain that its cyl. 4, I'm need to change the ignition coil, next. Please help!!
Old Dec 17, 2003 | 07:48 PM
I30tMikeD's Avatar
firewall
1 3 5
2 4 6
bumper
Are you getting a cylinder #4 misfire code?
Old Dec 17, 2003 | 09:59 PM
jinfiniti's Avatar
Originally Posted by I30tMikeD
firewall
1 3 5
2 4 6
bumper
Yes. and thanks for the info!
Old Dec 17, 2003 | 10:09 PM
I30tMikeD's Avatar
Before getting a new coil, swap coil pack #4 with #2 and see if the misfire switches cylinders. Then you know for sure it's your coil pack.
Old Dec 17, 2003 | 10:42 PM
jinfiniti's Avatar
Awesome...an easy answer..er, way to get my answer. I'm a little mad for not thinking of it myself...
Old Dec 19, 2003 | 10:59 AM
jinfiniti's Avatar
The coil pack or the ignition coil? Won't switching the coil packs mess up the firing sequence? Also, do you where the best places would be to get stock parts...such as the ignition coil.
Old Dec 19, 2003 | 11:14 AM
I30tMikeD's Avatar
You can swap coil packs from cylinder 2, 4, or 6. Cylinders 1, 3, and 5 use different types of coil packs and will not work in cylinder 2, 4 or 6.
No, swaping coil packs it will not change firing sequence. When you buy coil packs you buy then for either the right or left side (or it might be front and rear bank, I can't remember) not for each individual cylinder.
Old Dec 19, 2003 | 01:44 PM
jinfiniti's Avatar
Do you know of the best places to find stock parts, like the ignition coil?
I've found some for about $86.00 US. Please let me know if you can help. Thanks!!
Old Dec 20, 2003 | 07:41 AM
I30tMikeD's Avatar
I use the dealership when I had to purchased a coil pack. It cost me $95, but I needed it asap. I have heard that you can get them on ebay for cheaper, just make sure they are the OE coil packs. I believe 3 different companies made OE coil packs for I30's/maximas
Old Dec 22, 2003 | 12:41 PM
jinfiniti's Avatar
Thanks for all the help, Mike!!
Old Oct 7, 2013 | 07:40 PM
Jerry Eberhardt's Avatar
1997 nissan maxima
cylinder 4 misfireing on my nissan maxima switched coil to 6 changed spark plug wondering if someone has had the same problem and what they did next
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Sep 29, 2015 11:29 PM
imported_Nismo_max
Sep 20, 2015 08:19 AM
