EVAP sensor. ECU code 0704. Please help!
Old Mar 25, 2004 | 06:17 AM
GeneK's Avatar
Check engine soon light Is on. COde showing EVAP control system sensor has to be checked. I have no idea were this sensor is. ANybody had simmular expirience? Thank you.
Old Mar 28, 2004 | 07:53 AM
Kevlo911's Avatar
Kevlo for President
0704
Diagnostic Trouble Code 0704 points to a problem with the Evaporative Emission Control System Pressure Sensor. The EVAPCSPS is installed in the purge line. The sensor detects the pressure inside the purge line and sends a signal to the Engine Control Module. The signal voltage is directly proportional to pressure. The EVAPCSPS is not directly used to control engine operating parameters. It is used only to evaluate EVAP performance. Therefore a car with DTC 0704 should start and run normally.
The EVAPCSPS is located on the underside of the car near the left rear wheel. It is mounted near, but not directly on, the EVAP canister.
This malfunction is detected when the EVAPCSPS sends an out-of-range voltage signal to the Engine Control Module.
Possible causes include...
- harness or connectors (The EVAPCSPS circuit is open or shorted.)
- bad EVAPCSPS
- EVAP Canister Vent Control Valve is stuck open
- rubber hose connected to EVAPCSPS is clogged, bent, kinked, disconnected, or improperly connected
- EVAP Canister is damaged or saturated with water
- rubber hose from EVAP Canister Vent Control Valve to the water separator
- EVAP Canister Purge Volume Control Solenoid Valve
http://forums.maxima.org/showthread.php?t=265311
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
tseng1023
Oct 15, 2015 08:30 AM
zmcneely13
Sep 26, 2015 02:26 PM
