HELP HELP HELP.. my service engine soon light cam eon..
Old Feb 21, 2005 | 08:07 AM
HomerMAC's Avatar
Donating i30 Owner
why..? is it comming on.. everythign sounds good.. i cahnge all the things and lubes on time... hell sometimes few miles before time... what can i be..
the SERVICE engine soon LIGHT...
98 i30 with
95,125 miles on it.. what can it be.. help me... pLEASE
Old Feb 21, 2005 | 08:44 AM
Luigi38's Avatar
read 4 gen stickies
Old Feb 21, 2005 | 05:23 PM
i30ds's Avatar
Armed and Dangerous
Get the codes and then come back with more info!!
Old Feb 23, 2005 | 08:36 PM
HomerMAC's Avatar
Donating i30 Owner
the light went away..... i dont know.. i got into a little run with a civic hit 110 mph and then next day it wasnt there. the lgiht.... ? hmm now i dont know what ot do...
Old Feb 25, 2005 | 01:40 AM
00i30T's Avatar
Looks like you got a bad reading in one of your sensors, unless you get an ODBCII decoder, you won't know what it is, and even if you do get one it doesn't guarantee that it will tell you anything specific, such is my case.
The computer is saying that Bank 1 is running lean. I talked to my uncle who works for firestone and he says it could be multiple things so just reset it and see if it comes back frequently, seems like whatever part is failing is giving off a error some of the time, not all the time. ie O2 sensor.
Someone correct me if I'm wrong. PLEASE.
Carlos.
Old Feb 25, 2005 | 06:27 AM
HomerMAC's Avatar
Donating i30 Owner
yea it went away.. and it came back about 4 days later..
Old Feb 25, 2005 | 08:27 AM
98i30's Avatar
Get the codes while it's ON
Old Feb 25, 2005 | 09:01 AM
I30tMikeD's Avatar
Good God, just read the 4th gen stickies
Old Feb 25, 2005 | 09:15 AM
97I30touring's Avatar
lmao forreal
Old Feb 26, 2005 | 04:43 AM
HomerMAC's Avatar
Donating i30 Owner
heh what i stoppped posting about this.. hen the thread resurfaced.. hehe...
its the O2 sensor... i odbII it....
any thoughts on where i may attain one for reasonable price..?
Old Feb 26, 2005 | 06:39 AM
I30tMikeD's Avatar
www.oxygensensors.com
Old Feb 27, 2005 | 07:17 AM
HomerMAC's Avatar
Donating i30 Owner
oh siht... theres diff brand... which one do u reccomend I30tMikeD.. since ur ver knowledable about this.. and ur i30 is far superior to mine... no really it is... hehehe.. ok seriously.. does it make a diff...?
Old Feb 27, 2005 | 07:40 AM
I30tMikeD's Avatar
Get the OEM replacement type. They just plug in, the other type has to be spliced.
Old Feb 27, 2005 | 08:17 AM
HomerMAC's Avatar
Donating i30 Owner
ahh okie gotcha ya..
Old Feb 27, 2005 | 08:38 AM
flthere's Avatar
Even I got the SES light on yestday Gotta goto Autozone to check the codes ... everything runs and feels great, don't know what's wrong ... even my mileage is okk, recently got 24.8 on complete highway ... so i guess it's not the O2 sensor .. or I maybe wrong!!!
Old Feb 27, 2005 | 10:39 PM
i30ds's Avatar
Armed and Dangerous
What the HELL is up with every one going to autozone for the codes?!? They are perfectly retreivable using a flathead in a couple of minutes! Save your self the trip.
Old Feb 28, 2005 | 06:47 AM
flthere's Avatar
Well, I tried to pull the codes with flathead but it gave 0412 code which is Undefined!!! ya, four long pulses and 12 short pulses, I counted them 6 or 7 times ... But the SES light is still on this morning! And worse is the fact that it stalled when I started it this morning. Then I had to crank it real hard pressing the gas pedal and it finally started.
Old Feb 28, 2005 | 03:17 PM
flthere's Avatar
hi there,
i just obdii scanned it at autozone and it said O2 sensor Bank1 Sensor1. I'm sorry but I'm not sure if there are 2 sensors before the cat. Does it mean only the first sensor need to be replaced or both ... thanks guys
EDIT:
Also wanna know what bad happens with bad O2 sensor
Old Feb 28, 2005 | 05:23 PM
i30ds's Avatar
Armed and Dangerous
Well, if they are giving a false "too lean" signal, the injectors will begin to put more fuel into the mixture to correct this resulting in a rich A/F ratio, which will give you sh!tty fuel economy and mega power loss. If they are giving a false "too rich" signal, the injectors will begin to put less fuel into the mixture to correct this, which will result a lean A/F ratio and possible engine damage.
Just replace all three and you won't have to worry about it for another 75K.
Old Mar 1, 2005 | 04:24 AM
Pizatt's Avatar
My service light has been on for the last year... ****** misfiring coilpacks!
Old Mar 1, 2005 | 06:33 AM
flthere's Avatar
One last question, there are two brands of OEM type in oxygensensors.com, which one is preferred: Denso or Walker ???
Actually, almost two months ago, the heat shield over the cat came off and I didn't get it fixed. I guess the O2 sensor is right near that cat, and sthg must have hit the O2 sensor. Pothole roads all around. I don't want to pay taxes for such shytty roads ;-)
kjlouis
Nov 24, 2018 06:09 AM
Matt93SE
Apr 8, 2018 09:23 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Flores94
Aug 11, 2015 12:53 PM
