A/C not blowing cold...What to do?
Old May 25, 2005 | 09:55 PM
attomica
The A/C in my 2000 I30t isn't blowing as cold as it should. The compressor does come on and it does blow cool air, just not cool enough. I have a couple questions:
1. If it's not blowing as cold as it should, does that imply there isn't enough A/C refrigerant and that's caused by some sort of a leak in the system?
2. Does A/C refrigerant have a finite lifespan and the system must be purged and recharged on a periodic basis?
3. Can this issue be addressed at the nearby Firestone or should it be taken to the stealership?
Any other insight would be great because it's around 100° here. You can see my need to get this resolved.
Thanks.
Old May 26, 2005 | 12:03 PM
NewLoveI30's Avatar
You could take it anywhere that recharges A/C. They have to pressure check for leaks before recharging, so you'll know either way.
Old Jun 3, 2005 | 03:16 PM
Taxvictim's Avatar
On the 4th gens I know there is a sun sensor up on the dash right by the windshield (a little round button). If it's there on the 2000's, then make sure you're not blocking it with a radar detector or a parking pass or something.
I had this same problem on my last '96 I-30t. My belief was that the compressor was shutting down too quickly when I would put a demand on the engine. My solution was to rev the engine at about 2k rpms while coasting or stopped at a light. It seemed to make the AC blow colder.
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Noela
Sep 26, 2015 08:22 AM
pears
Sep 18, 2015 05:25 AM
