Variation on the OSCAI hacked air box theme
Old Jun 2, 2005 | 08:11 PM
dr-rjp's Avatar
If you're planning on doing a mod like the OSCAI, where you disconnnect the resonator tube below the snorkel and run a flexible hose to it, I found a better alternative:
2" ABS pipe, straight and elbows, available in the Plumbing section of Lowe's Home Improvement store. The pipe is a perfect fit to the snorkel tube, and you can use the existing 90 degree elbow, along with a second elbow, to run the opening out the bottom of your car:
Here's the view from the top:
Here's the view from below:
Since the two elbows are easily removable, you can take them off whenever it rains (like here in Florida), and put them back when it stops.
Anyway, I did it mainly out of curiosity, and decided afterwards to put the resonator tube back where it was after trying it out.
Old Jun 2, 2005 | 08:25 PM
I30tMikeD's Avatar
That would get ripped right off the car
Old Jun 2, 2005 | 08:50 PM
dr-rjp's Avatar
Probably, but I keep it rolled up to where it only sticks out half as much. I rolled it down solely for the photo op.
Now, I initially had the opening routed to come out behind the front bumper, but that would have necessitated cutting holes in the undercover, which I did not want to do.
Old Jun 4, 2005 | 07:09 PM
cefiro8701's Avatar
hmmm....question...why only two inches??
Old Jun 4, 2005 | 09:34 PM
dr-rjp's Avatar
Because the exterior of the 2" pipe fits perfectly inside the snorkel tube. The actual dimensions are larger than 2"
Even if you used a wider tube, the bottleneck is still the snorkel tube...
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
Sep 27, 2015 08:37 AM
