Overheating while idling
Old Jul 19, 2005 | 09:06 PM
bklynzsleepy's Avatar
My friend owns a 2000 I30t. It starts to overheat when it's idling for a couple of minutes. It would go up to about 3/4, which is right in between warm and hot.
Does anyone know what is causing this problem? Would it have something to do with the Engine Coolant Temp Sensor?
Thanks for your help in advance.
Old Jul 21, 2005 | 01:21 PM
bump......
Old Jul 21, 2005 | 02:18 PM
i30ds's Avatar
Armed and Dangerous
1. Did you check the coolant level?... There could be a leak.
2. If there is no leak, then some thing is malfunctioning... Either the termostat or the ECTS. Both are an easy fix.
Old Jul 21, 2005 | 03:00 PM
guysohigh's Avatar
SimStones
yea check the thermostat, mine would NEVER warm up, then would shoot up to Hot in like 2 secs, got a new one, been normal ever since.
Old Jul 21, 2005 | 04:40 PM
BikTrash's Avatar
Squeeze the outlet hose and see if the thermostat is working correctly. It could be a fan problem, check to see if the fan cuts on while idling
Old Jul 21, 2005 | 10:29 PM
Thanks for the feedback. I'll check the thermostat. The coolant level is fine. There is no leaks or whatsoever. The fans does turn on while being idled.
Once again, thanks.
Old Jul 22, 2005 | 08:13 AM
falconey's Avatar
More than likely it's the thermostat.
Old Jul 22, 2005 | 08:26 AM
njmodi's Avatar
Do I get a tax break?
How would a bad ECTS result in overheating?
Old Jul 22, 2005 | 09:37 AM
i30ds's Avatar
Armed and Dangerous
Sorry not the ects itself but the other little sensor right behind it. It essentially displays the engine temp on the gauge cluster. If it were to be malfunctioning, the engine would not be actually over heating, but it would be displayed that way.
Old Jul 22, 2005 | 01:46 PM
njmodi's Avatar
Got it.
Old Aug 15, 2005 | 09:10 AM
klschulte's Avatar
Make sure the fins on the rad are nice and clean.
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
