rattling side view mirror
Old Jul 30, 2005 | 09:30 PM
cefiro8701's Avatar
my right side view mirror keeps rattling at high speeds....anyone know how to stop this??
the left one seems to be fine...
Old Jul 31, 2005 | 03:59 PM
Dr.Monkey1313's Avatar
Have you tried pulling the trim piece off the inside of your door and checking to make sure all 3 nuts and bolts are tight? There is a triangle shaped piece that coveres the 3 nuts and bolts that hold your mirror on. You may want to start there. Hope that helped?
Old Aug 3, 2005 | 11:21 PM
cefiro8701's Avatar
nope....there are three screws under the mirror but i cant get to them...i'll have to scratch my car in order to do so.
Old Aug 4, 2005 | 05:48 AM
No no, not the three screws that are underneath your mirror on the outside of the car. I am talking about the three screws that hold the mirror to the door. If you look inside your door all the way to the front of the door (front end of the car on the inside) you will see a triangular plate (plastic). You need to remove the inside door skin and then unscrew one screw at the bottom of this triangle. Once you do that, you can remove the plastic triangle and you will see three screws. These screws hold the mirror onto the door. See if they are lose by any chance and if so carefully tighten them.
If you need more of a description or help, let me know. Good luck.
Old Aug 4, 2005 | 08:01 PM
cefiro8701's Avatar
yep...i had to take the whole door panel off to access it...i tried all six screws and they're all tight...wonder whats wrong...
Bluenissan
Sep 20, 2015 08:54 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
thenewguyy
Sep 12, 2015 11:12 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
flu2000
Sep 8, 2015 02:23 PM
