Re-wired my Fogs!
Old Sep 12, 2005 | 07:42 PM
NewLoveI30's Avatar
Re-wired my Fogs!
So I finaly decided to re-wire my fogs to come on with the city lights. I have never been real great with elecrical stuff, but tonight just confirms it.
So I realized that the write-up for the Max wasn't going to work because we dont have turn signals that double as clearance lights (thank god), and our wires are completely different colors too. The concept seemed easy enough to me though. All I need to do was find the positive lead in the fog lamp relay and connect it to any 12v source which opperates with the city lights... Easy enough huh?
Well, i used my voltmeter to find the positive lead, but made a mistake... I didn't have the car on so I found the wire with constant power. Of course I didnt realize this until after I had cut it. Solder that back together, turn on the car to find the wire with power when the fogs are on... Wouldn't you know it... There are two, and I choose the wrong one!
So long story short, if you are trying to do this on a 2000-2001 (not sure about 02+ probably the same though), you need to cut the pink wire (green stripe I think) and splice that with the red wire (positive) for the little city light bulb in the headlights (you could also use the sidemarker if you wanted).
This is a pretty cool mod though, and you can still turn the fogs on and off with the switch!
BTW, after I finished everything up, I saw that there is a damn diagram of the relay terminals right on the relay its self!
Old Sep 14, 2005 | 05:24 PM
OnEBadAsSi30's Avatar
yeah tried to do that on my 96 and totally screwed something up my parking lights dont turn on with the switch anymore and i figured out that it also controls your back lights so one night got pulled over for having no back lights i explained the situation to the officer and he said for me to get home and dont drive my car till i get it fixed and he let me go. so now i have a wire running from my battery to a switch to the 12 postive wire on my fog lights and it turns them on and the rears i have no idea what i did.
Old Sep 19, 2005 | 07:33 AM
bi30's Avatar
any pic newlove
Old Sep 19, 2005 | 07:56 AM
NewLoveI30's Avatar
I'll try to snap a couple shots tonight.
Old Sep 27, 2005 | 06:51 PM
ershi30's Avatar
I tried this but only one side came on. (the driver's side) Got any suggestions what may have went wrong?
Old Sep 27, 2005 | 09:09 PM
NewLoveI30's Avatar
Is your passenger fog bulb burnt out? That's really the only thing I can think of... Check fuses maybe?
Old Sep 27, 2005 | 09:40 PM
NewLoveI30's Avatar
Also, here are the pics I promised... Yeah, so it took a bit longer than expected
Old Sep 27, 2005 | 10:44 PM
cefiro8701's Avatar
sexy...good job newlove
Old Sep 28, 2005 | 08:49 AM
queenambeach's Avatar
What kind of bulbs do you have in your fogs? Did you use the Lexus capsule or have a 3000K HID kit? Dem things look hella bright for yellow fog light bulbs!
Old Sep 28, 2005 | 09:35 AM
StL I30's Avatar
Looks good NewLove. Can't wait for this weekend. You have LED's in the city lights?
Old Sep 28, 2005 | 09:38 AM
bi30's Avatar
did mine too
Old Sep 29, 2005 | 11:02 AM
NewLoveI30's Avatar
Those are just regular, off the shelf 55w H3's with the yellow capsules. And yes, I have super white LED's in the city lights. If you want to do this, go with the inverted lens LED's. I have used a couple others and they didn't fill the reflector as well as these.
bi30,
What kind of bulbs are you running in your fogs? They look really nice.
Old Sep 29, 2005 | 01:43 PM
bi30's Avatar
10,000k H3 HID bulbs, got a pair for $120
Old Sep 29, 2005 | 02:28 PM
clayman88's Avatar
Those look great! Do you find they cut through fog & rain alot better than the OEM bulbs? What do you mean by city lights though?
Old Sep 29, 2005 | 08:26 PM
NewLoveI30's Avatar
I dont really find much of a difference in rain or fog (or any other time) because the HID's totaly overpower them.
City lights, or parking lights as they are sometimes called turn on all lights except the headlights (tails, sidemarkers and the little bulbs inside the lowbeams). I guess the idea is that that you dont have to bug people with your headlights when driving through the well lit city.
I just use them during the day to make me more visible... especially with the re-wired fogs now.
Old Sep 30, 2005 | 06:41 PM
ershi30's Avatar
Finally got mine done.
Old Oct 2, 2005 | 10:41 PM
Max Mutes's Avatar
OMG...Those both look amazing!! NewLove's and ershi's...Couple question's...eershi what temp HID's are you fogs? 6000K?
NewLove, you have regualr 55w Hyper whites and put a yellow capsule over them, or just regular Yellow Ion bulbs? Cuz I got the Narva Rally's and they aint as yellow as yours, yours are perfect. Also, before you tried the inverted lens LEDs did you have/try Polargs? If so, and you like what you have better then I'll take your word for it and switch to whatever brand/type you got.
Also, to the A32's, is there any possible way to make our front end look like the A33's front end after we do the re-wire Fog mod with Parking Lights. Reason, I ask is because when we put ours on, my city lights show, my fogs, but also my amber parking lights next to the headlights. I wanna know if it's possible, that whe nthe headlights are off...can you make it so all you see is the white city lights and Fogs, no amber corners?
Old Oct 3, 2005 | 07:14 AM
StL I30's Avatar
Finished my yellow capsule install yesterday. Thanks for the guidance NewLove. They do look very good. An HID kit will be next for the fogs.
Old Oct 3, 2005 | 07:36 AM
clayman88's Avatar
That looks awesome, ershi! Nice job. What kind of kit did you go with?
Old Oct 3, 2005 | 08:11 AM
NewLoveI30's Avatar
I've just got some plain old 55w H3s you can find at any autoparts store, and I did install the yellow capsules. I really dont think any bulb out there can get even close to these in terms of color.
I dont think I've ever tried the polarg bulbs in my headlamps... I do think I have a couple hiden in my license plate lights though. I could replace one of the LEDs and check the difference if you like.
As far as re-wiring the corner lights on your car... I imagine you could wire them to the headlamps, but since your corners double as the turn indicators (I think) it would probably kill your signals with the lights off. You might want to check with the 4th gens, if anyone has done this I bet you would find them in there.
Old Oct 3, 2005 | 09:36 AM
n3985's Avatar
大陆弟弟
Nice! Are those regular halogen bulbs or an HID kit?
Old Oct 3, 2005 | 01:50 PM
ershi30's Avatar
Thanks for the input. I have an 8000K hid kit.
Old Oct 7, 2005 | 12:33 PM
I35Junkie's Avatar
ENVY!
I have got to get those capsules!!!
Old Oct 10, 2005 | 10:32 PM
Max Mutes's Avatar
Yeah man, not to bug you or anything, but if you have the time or chance to do that, I'd love to know which were brighter if there were any difference. I don't even need pics or nuttin, I'll take your word for it.
Also, did you just use the Lexus capsule or did you make your own somehow? LMK. Thanks.
Old Oct 10, 2005 | 10:36 PM
n3985's Avatar
大陆弟弟
Here is a thread I made about color dif in LEDs and Polargs as city lights.
http://forums.maxima.org/showthread.php?t=416197
Old Oct 17, 2005 | 10:33 PM
StL I30's Avatar
NewLove,
Did you give this guy permission to use your pic? He's using it to sell yellow HID kits.
http://cgi.ebay.com/ebaymotors/H3-30...QQcmdZViewItem
I'm gonna watermark all my pics w/ my name and maxima.org.
Old Oct 18, 2005 | 09:42 AM
below90hz's Avatar
Originally Posted by StL I30
NewLove,
Actually, as a photographer I can tell you that's seriously illegal. Any picture you take is automatically copyrighted, and if someone uses your picture for non-editorial purposes you have every right to demand they either discontinue use of the picture or compensate you for use of your image. First I'd take a picture of his ebay listing with your photo to have it on record. Then if you contact this guy and explain to him tactfully about copyright laws, you could tell him you are willing to let him continue use of the image for half off your next HID purchase or something. It's worth a shot...
Old Oct 18, 2005 | 10:13 AM
I35Junkie's Avatar
Half off? Screw that man! Get a HID setup for free!!! (get me one too)
Old Oct 18, 2005 | 10:18 AM
below90hz's Avatar
That'd be nice, but $200+ is a lot for one pic. The guy could take one himself of someone else's car or simply ask another customer to take a pic and give it to him for free. Most likely he'll just stop using the pic, but like I said if you are tactful and ask for reasonable compensation you might get something out of it.
Old Oct 18, 2005 | 10:22 AM
below90hz's Avatar
Oh BTW, nice fogs to everyone who posted pics. The yellow ones and the 10,000k ones are my fav.
(And with that gratuitous comment, I have met the 15 post count rule).
Old Oct 18, 2005 | 09:10 PM
NewLoveI30's Avatar
NewLove,
That's hilarious!
Hmmm.... Where have I seen that before? I think I will shoot out an e-mail just to give this guy some crap. I can't say that I really care (I'm actually quite flattered ), but after all, it is false advertising. LOL
Old Nov 6, 2005 | 12:03 PM
naijai's Avatar
well i finally rewired mine and i see it also flashes when i lock the car along with the city lights but that might be my keyless entry system
Old Nov 6, 2005 | 06:48 PM
bi30's Avatar
naijai - which wire did you tap into for fogs???
Old Nov 6, 2005 | 06:56 PM
naijai's Avatar
the pink and black wire under the fog light relay
Old Nov 6, 2005 | 07:01 PM
NewLoveI30's Avatar
Do you have an aftermarket keyless entry?
Maybe that was installed to flash the city lights and when you tapped into those it caused the fogs to blink too.
Old Nov 6, 2005 | 07:05 PM
naijai's Avatar
yes i do and i believe thats it and looks nice when they flash
Old Nov 12, 2005 | 11:16 AM
Crusher103's Avatar
So how do U rewire them?
Sorry I know its probly already answered just not to sure but how do U rewire the fog lamps, I cut them on and off when I want and with out having to turn on the regulary headlights, thanks
My car: 96 I30
Old Nov 14, 2005 | 09:32 AM
clayman88's Avatar
You should be able to find the answer to most of those questions here: http://forumz.maxima.org/showthread.php?t=204083
Welcome to the Forum
Old Nov 14, 2005 | 10:34 AM
Crusher103's Avatar
Thanks I'll post some pics when I do it
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
