service engine soon linght
Old Nov 22, 2005 | 01:22 PM
yonjun's Avatar
I have service engine soon light on.
I checked the owner's manual and the light will be on when there's a problem with exhaust system (O2 sensors or MAF etc I presume).
It's just the light came on after changing the alternator. Should I just reset it? how do I reset it?
YJ
Old Nov 22, 2005 | 04:39 PM
MetaOrbit's Avatar
Got Projectors?
Either read the FAQs in the 5th gen forum regarding the SES light (how to pull the code, how to reset it) or go to Autozone/Advance Auto Parts/Etc. and get them to hook up a code reader to pull the code for you and (maybe) reset the code.
Old Nov 23, 2005 | 06:10 PM
i30ds's Avatar
Armed and Dangerous
Old Nov 26, 2005 | 10:57 AM
KRRZ350's Avatar
Originally Posted by yonjun
It's just the light came on after changing the alternator. YJ
Sorry ds, I'm geussing you're saying this thread should be locked because it is in the wrong spot, but I just wanted to say this:
Did you not disconnect the battery when you replaced the alternator?? That's not very smart, I always disconnect the battery if I'm working on something anywhere even remotely close to the starter or alternator, or if theres gonna be fuel. If you didn't disconnect the battery you should read the service manual next time before working on your car. If you did disconnect the battery maybe you messed up that pita electrical connecton on the alt. or knocked something else loose, check the codes.
Old Nov 26, 2005 | 05:43 PM
i30ds's Avatar
Armed and Dangerous
yonjon should read the 5th gen faqs and then consult those guys... he's not going to get his answers here.
Old Nov 26, 2005 | 06:15 PM
yonjun's Avatar
I've read 5th gen FAQ and will try to read/reset the code.
thanks all for feedback.
YJ
Old Nov 27, 2005 | 12:44 PM
i30ds's Avatar
Armed and Dangerous
YJ
I dont know too much about the 5th gen ecu code reading... once you get the code definition, we might be able to help... but once again, if you get that far you might as well go directly to the 5th gen guys who probably have come across the exact same problem before.
shilov
Feb 19, 2024 09:40 PM
Pixel
Sep 15, 2015 05:53 AM
seesole
Sep 14, 2015 12:38 PM
Steven Orozco
Sep 12, 2015 10:41 PM
jfl330
Sep 4, 2015 01:44 PM
