2 subtle issues (odor in ECON, clunking noise in suspension)
Old Aug 20, 2006 | 12:31 PM
yonjun's Avatar
I have 2 subtle issues
#1. odor in ECON:
when the climate control is in Auto mode, all is well. but when I press ECON I could smell little odor. it is the cabin filter? or a/c system shoud be cleaned?
#2. little cluking noise/feeling in turn or over a bump.
when or after turning/going over speed bump etc, I feel something is shaking or clunking at the front end. I think something is touching something (feels as if some rubber piece hitting the chasis or something). I could feel it 2-3 times and it goes away as the movement of car settles down. it happens at low speed. very hard to explain in words
Old Aug 20, 2006 | 01:15 PM
i30ds's Avatar
Armed and Dangerous
maybe clean the ac system and replace struts.
Old Aug 20, 2006 | 06:01 PM
Dubzino's Avatar
Yes i30ds is right. Most likely the previous owner of the car was a smoker which can cause that odor. Just get the air system cleaner and you will be fine.But about that oise on the front i am really not sure.Hope this helps.
Old Aug 20, 2006 | 06:15 PM
yonjun's Avatar
the odor is coming from the vent. when the Auto is on, no smell. only when I pressed ECON the odor blows in (well it's not so much odor. but little discomforting smell I never experienced in my previous cars).
I know when the a/c condencer may develop mold or something so it could produce odor when a/c is on. But my case is the opposite. no smell with A/C on but when the ECON is on (the compressor(?) is off) odor blows.
was wondering if this is normal.
so little clunking feeling is from the shocks? shocks seemed to be ok although I've got 130k km on it.
Old Aug 21, 2006 | 07:30 AM
Dubzino's Avatar
Well I thoguht taht is what it is. Cause my car has 51,000km and has the exact same. When the AC is on all is fine but when I turn on the ECON is has a weird scent to it. I was told that is what the cause was from.
Old Aug 21, 2006 | 02:44 PM
i30ds's Avatar
Armed and Dangerous
Oh OK... the problem is opposite, sorry. In that case, try replacing the in cabin micro filter.
Old Aug 21, 2006 | 07:59 PM
yonjun's Avatar
air system cleaner... you mean can of spray that you spray from the out side (or engine bay) where the air is sucked in to cabin?
Old Aug 21, 2006 | 09:21 PM
Dubzino's Avatar
Yes that is what I meant. It really does a good job depending on which one you get.
Old Aug 21, 2006 | 09:47 PM
Uber-Oakley's Avatar
That reminds me. I should change my filter as I do get musty odor once and awhile.
Here is a link if you want to know how it is done:
http://www.greghome.com/Greg's%20Garage/2002MaxSE/In-Cabin%20Microfilter%20Change.htm
Old Aug 21, 2006 | 10:01 PM
yonjun's Avatar
thanks for the how-to.
I'll try the spray and filter change and see if it fixes the odor.
Old Sep 8, 2006 | 04:40 PM
yonjun's Avatar
#2 issue has been addressed.
The noise was the supproting bracket (metal piece) of the exhause pipe after the resonator. it was off and loose. welded it back on the pipe.
also the right ball joint was loose, it was replaced.
mechanic lifted the car up and played with the wheel and immediately blamed loose ball joint. I couldn't buy it so I started to check other area and found the piece of bracket hanging loose by the rubber.
I just let him change the ball joint becaue if it was loose it needs to be replaced anyways.
alahjahwan09
18
Sep 21, 2015 09:12 PM
jfl330
Sep 4, 2015 01:44 PM
pktaske
Sep 4, 2015 08:40 AM
A32goldylocks
Sep 2, 2015 06:39 AM
