Wheel spacers
Old 02-10-2007, 03:42 PM
C P Squared's Avatar
Wheel spacers
I dont know if any of you have noticed this, but the rear wheels and somewhat the front wheel arnt the even with the fender. Does anyone know where i can get spacers to make my rear and front ones a little more even.
Thanks,
Chuck
C P Squared is offline
Old 02-10-2007, 03:56 PM
One more thing, if i were to but these g35 rims
would the wheel/rim come even with the fender?
Old 02-10-2007, 05:03 PM
Pointy Elbows
00MaxSE's Avatar
You can get some H&R 5mm and 15mm spacers to help with that, but I think if you get the G35 wheels the offset is less, so they will be more flush with the fender. Nice user name BTW.
00MaxSE is offline
Old 02-12-2007, 10:59 AM
mtownyellaboy
So is it safe to say that there is 10mm difference in the front and rear offsets if you only want to even out the rear??
Old 02-12-2007, 11:19 AM
大陆弟弟
n3985's Avatar
I believe a 20mm spacer on the stock wheel brings out the rear flush to the fender. I have a DIY guide link to installing one, will post it later when I am home.
n3985 is offline
Old 02-13-2007, 11:26 AM
can you post it up for me?
Old 02-13-2007, 11:28 AM
大陆弟弟
n3985's Avatar
http://home.insightbb.com/~davidwhon...cer/spacer.htm
n3985 is offline
Old 02-13-2007, 07:35 PM
thanks a lot, and do u know what exact company makes the spacers you and your friend installed?
Old 02-13-2007, 07:42 PM
大陆弟弟
n3985's Avatar
1. I did not make the guide, I don't have a Maxima
2. Please read the site again to find the brand
n3985 is offline
Old 02-14-2007, 09:21 AM
Will the 20mm spacers be able to fill in the gap between teh wheel and the fender
Old 02-14-2007, 09:34 AM
Got Projectors?
MetaOrbit's Avatar
Measuring tape/ruler > you.
MetaOrbit is offline
Old 02-14-2007, 11:23 AM
NewLoveI30's Avatar
I put 15mm H&R spacers on my rears. The kit is hubcentric and includes the proper length studs for installation.
15mm doesn't come quite flush with the fenders, but it looks a lot better than stock and does not rub at all. Keep in mind that I am also dropped on Eibach springs. With my setup, I am of the oppinion that 20mm spacers would probably rub on large dips.
NewLoveI30 is offline
Old 02-14-2007, 02:10 PM
Pointy Elbows
00MaxSE's Avatar
That's weird. Maybe I30s maybe be a tad different from maximas. I had the 15mm's in the rear and I rubbed under hard cornering and a full tank of gas.
Did you recenter your beam? I have to do that in the spring in hopes of curing my rubbing problem.
00MaxSE is offline
Old 02-14-2007, 02:15 PM
Got Projectors?
MetaOrbit's Avatar
Was that with your 19s though? I think Newlove is still on his OEM 16" wheel + tire combo, so beam centering aside, it'll be different for everyone depending on wheel offset + tire profile and width.
I know you know I run 25mm spacers in the rear, but I had my own set of problems there...
Old 02-14-2007, 04:12 PM
Pointy Elbows
00MaxSE's Avatar
Yeah, that was with the 19s. Did you recenter your beam yet? You haven't responded to my IMs.
00MaxSE is offline
Old 02-14-2007, 05:00 PM
Got Projectors?
MetaOrbit's Avatar
LOL, sorry man, I've been between 2 computers, so by the time I get your IMs you're usually signed off.
Nahh, I haven't re-centered the beam yet. It's not a priority as I'm no longer rubbing ATM.
Old 02-14-2007, 05:10 PM
Pointy Elbows
00MaxSE's Avatar
Oh, gotcha.
00MaxSE is offline
Old 02-14-2007, 05:27 PM
Chassis Freak
VQuick's Avatar
Check this thread I started for info on spacers to make the rear wheels even with the fronts. I have some good links in the last post:
http://forums.maxima.org/showthread....hlight=spacers
Basically, 15mm spacers on a 4th gen Max or equivalent I30 (and probably a 5th gen Max/I35) will make the rears stick out ever so slightly more than the fronts without any spacers. This assumes all 4 wheels have the same size and offset, of course. It's nice to have a tiny stagger (with the rear track wider than the front) and since you can't get 10mm spacers 15mm is ideal. 20mm would be fine too.
VQuick is offline
Old 02-15-2007, 02:10 PM
NewLoveI30's Avatar
No beam re-centering here... Although I did replace the beam last summer
Yeah, and Im still riding on the stocker 16's.
Fbana41
08-29-2016 12:18 PM
Andy29
09-29-2015 05:32 AM
Lowered_a33
09-10-2015 09:41 PM
dcam0326
09-08-2015 11:02 PM
Maxboy23
09-04-2015 06:04 PM
Quick Reply: Wheel spacers
