Trunk not opening
Old Mar 4, 2007 | 12:05 PM
renman's Avatar
Trunk not opening
Hey everyone,
I have a 96 I30t. For the past three weeks, I thought my trunk was frozen shut, but now that's its thawed up, my trunk lid still is not opening.
I hear the actuator working, and it sounds like the trunk should open, but it's not. I looked at the 4th gen FAQ's and found the trunk lid section. I looked through my pass through in the back seat, but I cannot find a valet switch on the trunk lid. Is there a 4th gen I30 owner who could possibly help me out by opening their trunk and taking pics of the area on the inside around the lock assembly?
If you can point out where the valet switch is as well (if it exists on our cars) I would greatly appreciate it. As of right now, I have no idea. Oh my key doesn't open the trunk either.
Thanks,
Renman
Old Mar 4, 2007 | 12:15 PM
OnEBadAsSi30's Avatar
This for sure happened to me. I didn't know what to do. (I have 2 12"s in the trunk) So I had to take out my back seat with the metal plate. Crawl around my subs and basically take off the latch. Took about 20 minutes but after that I regreased it with some white lithium grease and hasn't happened since.
Old Mar 4, 2007 | 01:36 PM
i30ds's Avatar
Armed and Dangerous
Open it up with the key, and then move the valet switch off.
Old Mar 4, 2007 | 05:43 PM
MaximaExposure's Avatar
He can't open with a key either, so it may be something other than the valet switch. If it was frozen for that long, maybe it just needs some force to pop it open.
Old Mar 4, 2007 | 06:59 PM
C P Squared's Avatar
Just crawl on through the back
Old Mar 4, 2007 | 09:06 PM
i30ds's Avatar
Armed and Dangerous
Unless you are Houdini, you're not crawling through that small hole.
Old Mar 4, 2007 | 09:09 PM
i30ds's Avatar
Armed and Dangerous
Just try using all your muscle to pop that b!tch open!
Old Mar 4, 2007 | 09:14 PM
95maxrider's Avatar
Lightly modded
Nice ninja edit
I had this happen once. I had to get my lock drilled out and have a new one installed. It still won't open with the button, key only.
Old Mar 4, 2007 | 09:37 PM
i30ds's Avatar
Armed and Dangerous
Nice ninja edit
Damn!! I thought for sure I could get it by undetected.
Old Mar 5, 2007 | 09:36 AM
renman's Avatar
Yeah I've got my sub in there as well. I can see the latch moving, but I guess it's not moving enough, and I may have to adjust the striker plate.
And no, I'm not Houdini, I'm not fitting through that hole!
Hahah I'll try using all my muscle, but I doubt it will work. To bad I missed the ninja edit, I'm curious what was written before.
Thanks for the help chaps, I appreciate it. I'll probably try removing the back seat this weekend.
Old Mar 6, 2007 | 06:42 AM
guysohigh's Avatar
SimStones
This happened to me, and it ended up being the actuator not being tight enough, so i bought a used one from the org..
Old Mar 11, 2007 | 07:35 PM
renman's Avatar
Update: It was warm enough today that in the evening, I went out and tore into it. I took out the seats (easy enough, done it plenty of time for audio wiring) and slid myself into the trunk. After flipping a little switch on the trunk lid, I was able to open it.
It turns out that the latch (near the actuator) needed to be greased up. It would move, but not return. I greased up everything there (except myself )with some white lithium grease, adjusted the striker, and bam! It's good to go.
Thanks for all your input everyone.
Now it works with the remote and the key.
Old Mar 29, 2007 | 07:46 AM
Double E's Avatar
Looks like I'm gonna get the grease and look at the trunk lock mechanism this weekend.... Thanks all!
Old Apr 3, 2007 | 10:18 AM
renman's Avatar
Good luck!
REDinLV
Aug 15, 2024 12:30 AM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
mrgooch
Sep 21, 2015 08:43 PM
