Auto heater on-car wants to stall
Old Mar 7, 2008 | 10:14 PM
mboy2abq's Avatar
Help me out here guys!
I had one code showing, which was the coil code, so i just replace those. I thought that might take care of this problem too, but apparently not. So here's what happens(2000 AT i30)when i hit the auto button on climate control, the rpm's really go up and down, like it's missing a spark plug or something. If it's in park, or in drive with my foot on the brake, it will stall. I replace the radiator a month ago, and the problem has continued thru. Any ideas?
Thanks,
Mike
Old Mar 10, 2008 | 07:29 PM
Double E's Avatar
It sure sounds like a vaccum leak... Also, keep those old coils around, that may come in handy.
Just for giggles though (and a much cheaper route than the coil packs) remove & clean out the TB & IAC. It can't hurt, its DIY and in the process you might look closely for a line/thin black tubing either disconnected or off from the brake master cylinder area.
Interesting that you are not also getting more codes for this issue.....
Be sure to get the 2 gaskets for the TB & IAC when you do them
Old Mar 11, 2008 | 01:09 AM
gen4maxima536's Avatar
check your IACV
Old Mar 11, 2008 | 07:16 PM
mboy2abq's Avatar
Thanks,
Let's just pretend for a second that i'm not good with acronyms, althought i do get the dyi. What's TB, IAC and IACV?
Mike
Old Mar 12, 2008 | 05:35 PM
dineth00i30's Avatar
tb is throttle body thats all i know and ur car looks good i have the same color and model.
Old Mar 17, 2008 | 01:06 PM
mboy2abq's Avatar
thanks!!
I appreciate all of your input! After digging around in my engine area, i saw that the air filter from my cold air intake was disconnected. I connected it and problem solved!!!
LOL
Thanks Again,
Mike B
howardis
Dec 11, 2019 06:10 PM
BobTX10
Oct 7, 2015 08:43 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
