Tail Light not lighting up
Old Mar 20, 2008 | 08:33 AM
gakary54's Avatar
I changed my driver's side tail light(1157). Before, the light would come on when I turned on my lights, but would'nt light up when I stepped on the brake. Now the light does not come on with the lights, but works with the brake. Anyone ever have this problem?
Old Mar 20, 2008 | 08:47 AM
oldngivout's Avatar
Willing to learn
Yes, I have a very similar issue.
When I turn on the tail lights, all four bulbs across the tail section are lit.
But when pressing the brake, number 1 & 3 from left to right go out completely, while number 2 & 4 get brighter, as they should. Tried changing bulbs, checked everything obvious. Even tried disconnecting the spoiler third brake light, thinking it may be causing a load issue.
I'm still stumped........
Old Mar 20, 2008 | 09:05 AM
gakary54's Avatar
Thats the way it was with mine(press the brake, number 1 & 3 from left to right go out completely, while number 2 & 4 get brighter). I'm going to try and take the pass. side bulb and putting it in the drivers side.
Old Mar 20, 2008 | 09:09 AM
oldngivout's Avatar
Willing to learn
Just so you know, mine started out as the number 1 bulb doing that. But after I messed with it, it got worse. Now I'm like you, 2 out of 4 are going out.
Maybe I'll mess with it a little more
Old Mar 22, 2008 | 02:53 PM
MattB85's Avatar
I had a similar problem on my old Infiniti G20. The solution was to change out the taillight bulb holder.
Old Apr 3, 2008 | 03:28 AM
gakary54's Avatar
Okay, just noticed that left-most(#1) light is working fine now. Don't know how.
Old Apr 3, 2008 | 08:53 AM
dineth00i30's Avatar
check the relay
Old Apr 29, 2008 | 11:43 AM
gakary54's Avatar
Guess I spoke too soon, its back to the original problem. Im going to check the relay.
Old Aug 18, 2009 | 07:20 PM
mamasocks's Avatar
I just noticed tonight that my number 2 and 3 lights dont work when the lights are on and the brakes are pressed. They work fine when the lights are not on. I replace both bulbs and it didn't fix the problem. I noticed on of them was a little dim a few months ago and I was going to wait until it went out until I replaced it. Turns out it wasn't the bulb anyway
DJLAX152
May 4, 2021 11:46 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
