Suspension/Axle probems . . . . . .
Old Apr 9, 2008 | 04:33 PM
Chester86's Avatar
Howdy folks,
Good news is . . I just replaced the shocks/struts on my 2k I30. It solved my wheel rattling problem. The ride is extremely stiff right now and I am glad that chapter is done with. However, I noticed that when I took my car to test drive post shock/strut installation. The front end would hummm as I increased in speed. It at the point where it is unbearable. If anyone has any experience or suggestion what this may be . . .I'd greatly appreciate it.
--Chester
Old Apr 9, 2008 | 04:45 PM
nycspudz03's Avatar
sounds like you need Wheel bearings...
Chester86's Avatar
Also,
Before I replaced the shocks/struts . . I thought the problem on my car was the wheel bearings. I jacked the car up and 9/12 clock spots . . and shook it. There was no "play" or looseness.
Old May 4, 2008 | 12:51 PM
B_Eaze's Avatar
might seem like a stupid question but did you get an alignment after your install?
Old May 4, 2008 | 11:06 PM
KRRZ350's Avatar
^^That's not a stupid question at all, was about to ask the same thing.....
Originally Posted by Chester86
Also,
There isn't ALWAYS play, especially when they get wasted real quick from putting the car back down on the ground without the axle in it, that's a big no-no, you didn't do that during the install for any weird reason did you? Also, check to make sure that you don't have a brake line rubbing against the axle.
Old May 7, 2008 | 07:09 PM
Chester86's Avatar
Hip Hip Hooray . . . . . Problem solved and my I30 drives like a cloud now . . . *crossing fingers* I had the shocks/struts replaced which solved the wheel rattling problem. Afterwards, I'd hear a horrendous humming from the front right wheel that increased as the car sped up. I had the right wheel bearing replaced and saw that the wheel bearings warped a section of the bearing's casing. Had it replaced and now all is well so far!!
StevieB
Jan 6, 2011 09:38 PM
Amave
38
Apr 8, 2010 12:32 AM
BLACKKILA.GTR
Sep 12, 2009 02:18 PM
jreilly04
28
Jan 16, 2008 10:11 AM
NiSmOVQ35
Dec 31, 2007 04:59 PM
