Full Exhaust kit!!!
Old May 28, 2008 | 08:55 AM
SuBXeRo's Avatar
Full Exhaust kit!!!
ok, so im keeping the car and dumping money into it. My finances lack the liquidity and i would be strapped for cash, so i am putting 1500 or so into it. I may need a new exhaust system at some point so i need to know what to aim for. There seem to be a lot of ****ty crappy off shoot systems out there and im not sure what i should be looking for.
I want an exhasut system with larger pipes for better flow and it can be a little bit louder, but i dont want it to say upgraded muffler. I don't want to break the bank either but i also want some quality, "i wont rust in a year" system. I also would like to keep the same layout that it has now. Difference with a catback? frontback? sideback? haha, just a simple upgrade is all i really want if it comes to it.
Old May 28, 2008 | 09:59 AM
rxm6's Avatar
Just my advice, but don't go with bigger pipes. If your running an S/C then, by all means, stick 4" exhaust pipes on the car. However, any bigger pipe on a stock engine won't allow enough back pressure and you'll actually be losing power. The best thing for you to do is buy a stainless steel y-pipe and b-pipe from either cattman or lyell's and leave the stock muffler on. This will still give you a nice little growl without the loud fart common to most aftermarket mufflers. Plus, stainless y and b-pipe will cost you about $600 and you can use the other $600 for something else.
Old May 28, 2008 | 11:02 AM
MrRogerStatus's Avatar
VQ Disciple
Good idea
Old May 30, 2008 | 05:17 PM
KRRZ350's Avatar
Allthough you are partially correct, and not just in the fact that 4" is overkill. But it's been dyno proven that vq's do take well to 3" in n/a form. Just an FYI, but excessively large pipe diameter reducing power has NOTHING to do with back pressure, it's because of the heat, perfect sized piping = hotter exhaust gasses = better flow.
Old May 30, 2008 | 11:22 PM
rxm6's Avatar
I agree completely with the thermodynamic efficiency of smaller pipes. That hadn't actually crossed my mind. But how does reducing power have nothing to do with back pressure? While I admit, in the strictest sense of the word "losing," you are not losing power. However, doesn't absence of the proper amount of back pressure create a "backup" in the ventilation of exhaust gases causing those gases to remain in the cylinder and thus being burned a second time. Losing power might not be the right word to use but wouldn't lack of back pressure create an inefficient burn?
Old May 31, 2008 | 05:34 PM
SuBXeRo's Avatar
ok, so its settled, i will trust your judgement and purchsase a nice stainless steel system, any suggestions on who would supply a good stock replacement exhuast system with beter quality materials?
Old Jun 11, 2008 | 10:30 AM
CreativeDesignz's Avatar
whatever you do DO NOT buy from warpspeed...i got my stuff from there took them 4 months to ship it/"build" it and got the run around the whole time. They are really a bunch of as*holes over there not to mention the shi*tiest fitment ever imaginable
Old Jun 12, 2008 | 02:54 PM
Teecee's Avatar
I too would like to know. Still want to pass emissions though.
A32goldylocks
Sep 16, 2015 01:33 PM
Maxboy23
Sep 4, 2015 06:04 PM
TheMafia
Sep 4, 2015 08:26 AM
A32goldylocks
Sep 2, 2015 06:39 AM
