Y-pipe Installation Problem
Old Jul 29, 2008 | 09:10 AM
McSteve's Avatar
So I took my car to the shop today, to get the UR UDP installed, and my HKS tips extended, and thought it would be a good idea too, to let them install my stillen Y-pipe. Well turned out they won't do it. Neither would the three other shops I asked at. "Tampering with a federal emissions device" or some crap like that. Did anyone else run into problems like that? Looks like I gotta get under the car myself later on. Don't look forward to loosening those bolts.
Old Jul 29, 2008 | 09:16 AM
n3985's Avatar
大陆弟弟
Very common, since you are in the South at least you don't need to worry about rusted bolts, a big can of PB Blaster will be your friend!
Old Jul 29, 2008 | 09:50 AM
Norkoastal's Avatar
Tuner shops should be able to help out...
Old Jul 29, 2008 | 10:36 AM
burgy's Avatar
^Yeah, go to a speed shop or a tuner type and you'll be fine.
Old Jul 29, 2008 | 06:22 PM
KRRZ350's Avatar
Or check the regionals section and help support a local .org member
Old Jul 29, 2008 | 09:58 PM
McSteve's Avatar
Well well well, I ended up working on it all day and finally got it done. Tooke me a couple hours, laying under lowered cars sucks! Was a royal PITA. And I think i have exhausts leaks now, the nice mellow tone of only the HKS went to a ridiculous loud roaring and i am hearing a really high pitched noise too. Soo I need to get that checked out pretty soon.
The muffler shop charged $190 to cut my rear valence, extend the muffler tips, put the rear section on and slap on the Unorthodox UDP, so I can't complain about that.
and @KRRZ350
are you implying you are local? =D
Cos i need someone to check if I have leaks, and fix em, i'm not getting under that again. (for a while)
Old Jul 30, 2008 | 09:50 AM
mmg23max's Avatar
If you end up doing it yourself get yourself a torch also with the above listed item.
Old Jul 30, 2008 | 10:48 AM
n3985's Avatar
大陆弟弟
I demand pics of the exhaust with Ionic rear lip!
Old Aug 9, 2008 | 04:58 AM
B_Eaze's Avatar
Did you raise it????
Old Aug 9, 2008 | 09:45 AM
McSteve's Avatar
raise what?
Old Aug 9, 2008 | 01:12 PM
B_Eaze's Avatar
your car, you said its hard working under a lowered car (springs right?) so i was wondering if you jacked it up or put it ramps or something
Old Aug 9, 2008 | 08:26 PM
McSteve's Avatar
well yeah, i raised it up on jackstands and a floorjack, that's the only way you can even get to anything under the car.
Old Aug 10, 2008 | 05:08 AM
KRRZ350's Avatar
and @KRRZ350
Unfortunatly I am not :-( Best way to find leaks is to get under there when it is running and cold. An automotive stethescope (VERY useful $12 tool) with part of it unplugged so it is just the earpeice and hose, can help pinpoint them a little easier as well. It's possible the front flanges aren't anywhere near fully seated.
Just a quick word about safety as well (And I feel your pan about lowered cars) You always want to use the proper jack and jackstand points in the FSM (engine x-member + pinch welds) and once the car is on jackstands rock it back and forth hard a few times, better it fall on the ground than fall on you.
JRod28
Dec 29, 2023 09:56 PM
VQ'ed
69
Aug 27, 2020 12:29 PM
stromm
Aug 27, 2015 04:13 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
