What do I need to buy in order to give my i30 a tune up @ 175,000 miles
Old Aug 3, 2011 | 08:51 PM
edubz's Avatar
I have a 2000 infinit ii30 and wanted to know what I needed to buy to give my car a tune up.
The codes I got for the machine were
p0300 (random misfire detected)
p0400 (ERG airflow)
P1320
p0420 (Catalyst System Efficiency Below Threshold (Bank 1)
will a tune up fix these issues?
Old Aug 3, 2011 | 08:53 PM
Joeker82's Avatar
Po420 - I believe is a O2 sensor.
Old Aug 4, 2011 | 08:22 AM
edubz's Avatar
how many o2 sensors are on my car?
how do I figure out which one needs changed
Old Aug 4, 2011 | 08:33 AM
tsi1991awd's Avatar
Bank 1 is the front O2 sensor....there are 3 sensors if I remember correctly.
Random misfire may be cured by new plugs....if not, one of your coils may be going bad.
Tune up usually consists of spark plugs, oil change, air filter, other fluid changes (power steering, coolant, brakes), possible tranny flush if you havent done it in a long time.
Also, it wouldnt hurt to give your car the seafoam treatment....one can in your oil and half can sucked through the vacuum hose on your intake manifold....shut car off and let it sit 5-10 minutes. Restart car and hold RPMs around 2000-2500 and watch the smoke bellow out. After 3-5 minutes, take it for a drive and floor the pedal at times.....this will clean out all the carbon buildup in the EGR, intake manifold, cylinders, etc. CHANGE OIL AND SPARK PLUGS AFTERWARDS.
Old Aug 4, 2011 | 04:13 PM
Nugent20's Avatar
Ive heard seafoam is good as a fuel stabilizer too, any truth to that?
NGK
Old Aug 5, 2011 | 05:32 PM
tsi1991awd's Avatar
NGK
Yes, it will clean out your entire fuel system as well. Best fuel treatment you can buy IMO. I run one can in the gas tank every other oil change.
Old Aug 6, 2011 | 05:21 AM
edubz's Avatar
does anyone know how many coils are on my i30?
Old Aug 6, 2011 | 06:56 AM
pahanorlando's Avatar
Six
Old Aug 7, 2011 | 06:55 PM
memphisballer's Avatar
P0420 is most likely your catalytic converter.My I30 was serviced with this
same code before I bought it and mine was replaced along with O2 sensors.P1320 is one of
those codes that may be easy to fix by replacing all coils or could be hell trying to figure out and can be caused
by something else like cam or crank sensors.More info can be found in 4th or 5th gen forums.
http://forums.maxima.org/5th-generat...cali-spec.html
Old Oct 11, 2011 | 09:01 PM
Infi30t's Avatar
Just go ahead and do plugs, throttle body clean, fluid changes (Oil, tranny, Brake, etc.)
Old Feb 13, 2013 | 08:46 AM
Br0nz's Avatar
nah that's the front pre-cat !
Old Feb 14, 2013 | 04:04 AM
Rob1224's Avatar
ive got the same p0420 code..if it IS the cat converter and not the O2 sensor, how much is a new converter usually? Definitely dont feel like being ripped off -.-
Cotozic
Jun 28, 2017 08:01 PM
Maxima_Joe
Oct 15, 2015 08:01 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
Quickgtp
Aug 27, 2015 02:13 PM
kirkhilles
Aug 8, 2015 10:53 AM
