2000 i30 rear view mirror mounting
Old Sep 12, 2013 | 07:09 PM
gapboi210's Avatar
My rear view mirror fell off and broke. I got a replacement. The metal piece is still on the windshield. There is another piece that goes onto that and then the mirror. Even after tightening everything you can just lift the mirror off the mount. I have looked at schematics and I am not missing any parts and it only seems to go together one way. BTW Infiniti wants $1010 for a new mirror.
Old Sep 12, 2013 | 09:04 PM
DennisMik's Avatar
I don't know why the mirror won't stay on, but I looked up the price at an Infiniti dealer in my area, Grubbs Infiniti.
Was the dealer by you wearing a mask and pointing a gun at you when he told you that price?
I found 2 mirrors. Not sure which one is the correct one but they are pretty close to the same price.
INFINITI I30
MISCELLANEOUS > REAR VIEW MIRROR > MIRROR ASSY-INSIDE
Part Number: 96321-53U00
MSRP: $850.78 Online Price: $680.62
MISCELLANEOUS > REAR VIEW MIRROR > MIRROR ASSY-INSIDE - F/AUTO ANTI GLARE MIRROR - F/SUNROOF + LEATHER SEAT
Part Number: 96321-53U02
MSRP: $866.08 Online Price: $692.86
Still no bargain, but...
Old Sep 12, 2013 | 09:38 PM
gapboi210's Avatar
I saw the same prices but they said due to it being a discontinued item the new list was $1010.00
Even $600 is retarded for a mirror. I just cant figure out how the hell it stayed mounted on there. All the pieces fit together but don't hold together.
Old Sep 12, 2013 | 09:50 PM
MaxMike93's Avatar
There's a small clip that holds the mirror onto the metal piece. For me, it would constantly slip off one or the other whenever I'd try to put the mirror on. My dad helped me and put a dab of silicone to hold the clip onto the metal piece on the windshield to keep it from slipping off.
Old Sep 12, 2013 | 10:09 PM
gapboi210's Avatar
Here is a video of my problem:
Old Sep 12, 2013 | 10:12 PM
gapboi210's Avatar
BTW I bought a second mirror and it is exactly the same
Old Sep 13, 2013 | 02:55 PM
David3267's Avatar
How about u upgrade that mirror to a i35 mirror I sell them cheap with the wire harness and the torX bolt.u won't need any of that mounting bracket nonsense u just pop it on and TorX screw it down
Old Sep 13, 2013 | 09:55 PM
gapboi210's Avatar
The mount on the windshield is different. I would need to remove the old one and attach a new one.
Old Oct 8, 2013 | 12:41 PM
Ed Bwoy's Avatar
I have spare i30 mirror and of course I disassembled it and reassembled it. Same problem you had. I gave it about 3 mins of my time and it seems I found a way to work it. I'll try to describe this to the best of my ability.
1. Lay the mirror flat so that the windshiel mount is on the left, and the bottom(button) side of the mirror is on your right.
2. Use an appropriate Philips head to unscrew the holding screw all the way until the clip falls off.
3. Now you should have 3 pieces: black mounting plate, the clip and the mirror. The hook side of the metal clip is on top
4. Mount the metal clip with the bottom going into the black plate first, then the hook. It will be held back by both the bottom and the top(hook) of the clip, so just slide it down.
The point here is to have the clip held by 2 points, not just the hook but the bottom as well
5. Now put the mirror plastic on it and put the screw back in
6.Enjoy your tightly mounted rear view mirror
Question: What caused your mirror to fall in the first place?
Edit: I realize the orientation of all this will be off since you're mounting it on the windshield. I did my test on a desk. Just make sure you hook both top and bottom of the clip
JRod28
Feb 4, 2016 11:07 AM
Huttig2009
Sep 25, 2015 03:31 PM
Maxilano
Aug 31, 2015 07:33 PM
Quickgtp
Aug 27, 2015 02:13 PM
BobMax
Aug 19, 2015 04:39 PM
