leds keep blowing tail light fuse
Old Jun 13, 2014 | 09:00 PM
cheech_11's Avatar
so i installed leds for my license plate and those were fine. today once i installed two more into the front door puddle lights and two for the parking lights i blew the tail light fuse. id like to make the parking, puddle, dome, and map lights led but how can i do it without blowing the fuse instantly?
Old Jun 14, 2014 | 07:20 AM
cheech_11's Avatar
update: found out that its the parking bulbs that keep blowing the fuse when i convert them. i switched the trunk, puddle, reverse, and license plate lights to led and everything is fine. i guess there was too much heat in the headlights or something? anyway next is the dome and map lights. does anyone think there will be a problem with blowing a fuse with those? thanks!
Old Jun 14, 2014 | 09:19 AM
CMax03's Avatar
You have a light short somewheres maybe in the hottest bulb....VOM time!
Old Jun 15, 2014 | 10:24 PM
cheech_11's Avatar
vom?
Old Aug 16, 2014 | 10:33 PM
King_Ten_Ahead's Avatar
Mine did the same thing a figured it had to have something to do with my fog light rewire.. But it turned out to be my dimmer switch failing.. I unplugged it and put it back in and it worked again! Just thought Id share in case youd like to give it another go with those bulbs
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Maxima30
Sep 7, 2015 06:13 PM
jds22
Sep 4, 2015 01:52 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
