Power steering pump bolt
Old May 14, 2016 | 01:52 PM
camako's Avatar
I have an '03 I35. I'm in the process of removing the front timing chain cover to fix the infamous tensioner guide problem. I am doing this without dropping the engine. It's been an ordeal but I have managed so far - thanks to a couple of videos I found on YouTube, especially those by 2012nugget (kudos to him).
I have literally one bolt left to remove before I can pull the cover off, and that's the power steering pump bolt. The head of the bolt is on the engine side and I'm not able to get a socket on it. Anyone who has done this job will know what I'm talking about. The FSM or the videos are no help in this. Boy, talk about a tight space. You can barely see this bolt much less reach it, or get a socket on it.
I am really hoping someone has a trick that I can use.
Thanks in advance
Camako
Old May 15, 2016 | 03:43 AM
DennisMik's Avatar
That sounds like the bolt used to adjust the belt tension.
Maybe this video may help you.
iTzCloud
Apr 9, 2016 08:06 PM
zillafreak
Mar 21, 2016 09:36 AM
TriniMax3.0
Mar 18, 2016 05:11 AM
gpgoodpeeps
Mar 12, 2016 10:18 AM
A36-SR
Mar 4, 2016 05:21 PM
