Just bought an '02 Infiniti I35, may need timing chain?
Old Jul 11, 2016 | 04:38 PM
2002_Infiniti_I35's Avatar
Just bought it yesterday for $800 off Craigslist. It has 183,000 miles. The engine runs smooth, but it was about 2.5 quarts low on oil when I went to see it & had kind of a sloppy start condition when the engine was warm where you had to give it a little gas to make it idle after starting it. The SES light was on also. The codes were: P0011. A misfire code on the 5th cylinder. An O2 sensor fault. And an emissions fault. I had the CPS replaced today which seems to have helped some with the sloppiness after starting, but before I even left the shop the code P0011 popped back up and it developed a hard start, it takes roughly 4-5 seconds of turning the key for it to crank up now. The shop is telling me it could be timing related, but I haven't seen many online reports of timing chains failing on these engines. What could this be??? Any help would be appreciated.
Old Jul 26, 2016 | 04:29 PM
JvG's Avatar
JvG
You will find much more information on the maxima
Forum for your year.
Timing chains are NOT a common problem. In fact, they are Never a problem.
Old Jul 27, 2016 | 11:42 AM
murphys_law's Avatar
If it was that low on oil the bucket lifters are probably smashed causing it to tick. I just repaired one with the exact same damage.
Old Jul 30, 2016 | 06:23 PM
JvG's Avatar
JvG
The lifters at e mechanical, not hydraulic.
Old Jul 30, 2016 | 06:26 PM
JvG's Avatar
JvG
check your crankshaft position sensor (cps) remove connector, clean off any oil, then shoot with either electrical contact cleaner or brake cleaner.
Brianc72gt
Mar 24, 2016 12:00 AM
ShunDoe
45
Mar 8, 2016 07:52 PM
SR20Power
Mar 1, 2016 11:41 PM
SR20Power
Mar 1, 2016 11:40 PM
Dman5683
Feb 29, 2016 03:13 PM
