99 Maxima SE gauge cluster in 96 i30
Old Dec 8, 2017 | 10:57 AM
carguy87's Avatar
Does anyone know if the 99 Maxima SE gauge cluster fits in a 96 i30? They look brighter and they have white faces. Looking to put LEDs in there while I'm at it. But I'm wondering about electrical connections, etc. if everything within the cluster will be functional.
Any help is appreciated.
Old Dec 9, 2017 | 11:58 PM
DennisMik's Avatar
The 1995 & 1996 maxima cluster is plug & play with the 1996 infiniti.
The electrical aspect of the 1997 to 1999 maxima instrument is different from the 1996 infiniti (and maxima). The 97 maxima cluster would would seem like plug & play but the electrical signals don't match up. The 1998 & 1999 maxima has a different wire harness connector
Old Dec 10, 2017 | 12:15 PM
vipervadim's Avatar
I like Maximas
Yes it will physically fit and mount...
But the harnesses in the back are different.
However if you match up and splice the wires to your existing 96 cluster harness it will work. Even the digital odometer(mileage of donor)
I did it on my 96 i30t with a 98SE max donor cluster and cut harnesses from a junk yard.. but it's like ~30 wires.. so if you're not comfortable with wiring and patience to work in an annoting area then ask someone who is to do it
you can get all the pinouts in the corresponding 96i30 and 99max FSM EL sections
Old Dec 28, 2017 | 10:36 AM
carguy87's Avatar
Perfect. Thanks guys
ZNUT
Feb 19, 2014 02:57 AM
5 ltr. beater
Dec 16, 2013 05:31 PM
maxfever1987
25
May 1, 2011 09:28 AM
embraer
Jun 20, 2006 02:53 PM
Michael J.
Jun 13, 2002 06:03 AM
